03-24-2020
06:15
17:34
DavideFitbit
03-24-2020
06:15
17:34
DavideFitbit
The left half of my Fitbit Versa screen will not respond when I touch it. When I move to the right side it starts moving on it’s own. This has been happening for quite a few days and I cannot even set alarms anymore. I tried a factory reset and nothing has worked. Do you have a solution? Something I can do to fix this issue?
03-24-2020 06:22
03-24-2020 06:22
Notting you can do. It`s a firmware bug.
Best Answer03-24-2020 06:52
03-24-2020 06:52
Is the screen clean?
Have you tried a restart. Press left and lower right buttons.
Best Answer03-24-2020 07:28
03-24-2020 07:28
Best Answer03-25-2020 08:19
03-25-2020 08:19
Best Answer03-25-2020 09:12
03-25-2020 09:12
Have you contacted Fitbit?
Best Answer04-20-2020 10:12
04-20-2020 10:12
Did you get a fix for this? Mine has done the same! Won’t respond on left side and screen keeps flashing on/off .
Best Answer04-20-2020 14:04
04-20-2020 14:04
Best Answer04-20-2020 14:20
04-20-2020 14:20
I was in the middle of a workout and it just started buzzing constantly, it then went on to a coach workout without me pressing anything and I couldn’t exit that! Then realised it wasn’t responding on left hand side, tonight it keeps randomly going through passcodes on the screen. It’s still counting steps at present but can’t do anything else. I use mine to control my music on my iPod as I’m a fitness instructor ( thankfully not using it for that at minute.) thanks for replying.
