04-07-2018
04:22
15:02
AlessFitbit
04-07-2018
04:22
15:02
AlessFitbit
I have received my Versa Thursday and after 2 hours of charging it. The battery got drained within 6 hours. I have charge it on a PC. last night, slept with the watch to wake up to see my watch is down to 0%. Any other user having this problem? Should I waiy for an update to correct that or its a harware problem. Thank you for your answers.
Moderator edit: title for clarity
08-30-2018 05:57
08-30-2018 05:57
08-30-2018 06:27
08-30-2018 06:27
08-30-2018 06:52
08-30-2018 06:52
The rumor is the new I watch is coming out in September. With better battery life and bigger screen. Well see. cw11
08-30-2018 07:01
08-30-2018 07:01
Battery life was 4 to 5 days when i first got my Versa but after a few weeks, it will barely last two days. I have turned off all notifications and everything else that may affect the battery life per suggestions in this thread and still cannot get more than two days battery life. Did something change recently? I would not have bought this particular tracker if I had known the battery life would be so short...
Does anyone have suggestions on what the next course of action is?
09-04-2018 01:28 - edited 09-04-2018 01:28
So frustrated with the Versa - my first Versa battery would not hold any charge longer than 12-14 hours & that was replaced. The replacement has been working well for about six weeks & now it has just died with still more than 50% charge. Screen is black, will not charge or reset or anything. Surely FITBIT should recall this faulty launch, it is definitely damaging the FITBIT reputation.
09-04-2018 05:07
09-04-2018 05:07
09-05-2018 16:14
09-05-2018 16:14
Hi there, I've had my fit bit versa for under a month and a full battery foes not even last a full day. Not sure what to do ... Any suggestions??
09-05-2018 19:29
09-05-2018 19:29
Contact customer service via Twitter, they will run some diagnostic analysis & will send you a replacement once they validate there is an issue. Such a shame the Versa is a dud as it is has the potential to be a great fitness watch / tracker.
@Dheisha wrote:Hi there, I've had my fit bit versa for under a month and a full battery foes not even last a full day. Not sure what to do ... Any suggestions??
09-06-2018 06:42
09-06-2018 06:42
09-06-2018 07:34
09-06-2018 07:34
My third one is syncing and holding a charge.
09-06-2018 08:05
09-06-2018 08:05
09-06-2018 08:08
09-06-2018 08:08
Get onto fitbit support by email and by DM on Twitter as Twitter will answer you quicker than email but you will have needed to email them otherwise that's what they'll tell you on twitter to do. They will follow your watch activity and if shows faulty will replace it ss that's whav they did for me.
09-06-2018 16:51
09-06-2018 16:51
09-07-2018 13:57
09-07-2018 13:57
I got mine in June and only had to charge it every 4-5 days as well. But I guess for last couple of weeks it's been draining so fast. After less than 11 hours it's down to 49% right now. And that's just a work day. Nothing strenuous.
09-12-2018 08:17
09-12-2018 08:17
Yes, I just went through 2 days of "chat" trying to get this fixed. I'm so upset. I've had the Versa since May. They won't even replace it. Per the warranty I should get 1 year. I'm going to try and find a Samsung product. I've been a customer for 6 years and the Versa is a huge dud. They need to recall it. They wanted me to take a picture of my Versa on a piece of paper and send them the picture with some numbers written on it. Replacement process it ridiculous.
09-12-2018 08:49
09-12-2018 08:49
09-14-2018 07:00
09-14-2018 07:00
Hello guys, I hope you are doing well.
I appreciate all your efforts in trying to fix this issue and the feedback provided.
If you have already tried the instructions provide in this post and keep experiencing battery problems, feel free to get in touch directly with our support team. For a faster response you can contact them via chat.
Let me know if you need anything else.
09-14-2018 07:06
09-14-2018 07:06
09-16-2018 18:20
09-16-2018 18:20
I started having major issues with my versa battery life this weekend. Friday evening the battery showed 65% life. Shortly before 5 a.m. my versa buzzed and woke me. The screen was a blank glow. When the clock finally appeared, the second hand would show delays in advancing. The device repeated the buzz and blank glow before completely dying. I gave the device a full charge (wall outlet) and put it back on. $ hours later ... dead again. Put it back on the charger (now on a different outlet) and all it did was glow the Fitbit logo. I took it off the charger after several hours of this to give it a "break" then put back on the charger hours after that. Once it was fully charged again, but then dead again within an hour.
I put in a call (help chat), they gave me things to do to improve battery life and options on how to "test" the battery life. If it can't hold a charge more than an hour, I'd say time for a switch. Does everyone have some type of battery life issue using the versa?
09-16-2018 22:50
09-16-2018 22:50
Well I just got the replacement and everything seems ok for now. Will just have to wait and see .
