12-25-2020 11:42 - last edited on 12-25-2020 15:26 by LiliyaFitbit
Versa steps says undefined, hourly steps says NaN, heartrate just dash lines. Restarted watch no luck, data I'd showing in the app
12-25-2020 12:36
12-25-2020 12:36
It sounds like you are using a third-party clock face. Sometimes they don't keep up-to-date with Fitbit changes. I suggest switching to a clock face "by Fitbit" and see if that works. If so, then you can experiment with other clock faces you like to see which work right.
Best Answer12-25-2020 12:36
12-25-2020 12:36
Best Answer12-25-2020 12:57
12-25-2020 12:57
I've used the same clock face for a long time without issues. I did change and it is good now thank you
