10-11-2021
07:32
10:59
10-11-2021
07:32
10:59
Took watch off charger this morning and then it would light up after I put it on
10-11-2021 11:00 - edited 06-21-2024 11:34
@Ww017 Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa.
Please restart your Versa as suggested here How do I restart my Fitbit device? If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Hope this helps.
Best Answer10-11-2021 11:00 - edited 06-21-2024 11:34
Hope this helps.
Best Answer10-12-2021 12:16
10-12-2021 12:16
I tried this and it turned back on but something is wrong with my fit bit and I need a new one ot is still nothing working properly all the notifications are going off and when I put it on charge overnight the entire watch face came off
Best Answer10-12-2021 13:14 - edited 06-11-2023 13:34
@Ww017 I appreciate you had followed the tips and recommendations provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
