08-04-2020
09:12
20:13
RicardoFitbit
08-04-2020
09:12
20:13
RicardoFitbit
Hi there. I have been having problems with my Versa for the last 3 weeks. I thought I had solved it- by following advice on here, but now my Versa is stuck on the 'Source screen' and none of the buttons work so I can't do a factory reset or get it back to the time screen.
What should I do next?
thanks for helping me. Naomi
08-09-2020
15:14
10:00
08-09-2020
15:14
10:00
You're welcome @NaomiParker, sorry for the delay in responding your post. It's a pleasure to continue assisting you.
I appreciate your effort troubleshooting your Versa with the steps that were shared on my previous post. Because the issue wasn't solved, let me share with you that our Customer Support team was contacted on your behalf to provide you further assistance with the difficulties you're currently experiencing. Please keep an eye on your email inbox because they'll be in touch with you pretty soon.
In the meantime they contact you, let me know if you have any additional questions.
08-04-2020
20:13
10:50
08-04-2020
20:13
10:50
Hi @NaomiParker, welcome to the Community Forums!
Thanks for bringing this to our attention and for trying some troubleshooting steps before posting over here. To further investigate and better assist you, can you please send me a picture of what your Versa is currently displaying?
I'll be waiting for your reply. Let me know if you have any additional questions.
08-05-2020 01:35
08-05-2020 01:35
Thanks for your reply. Here is a picture of the screen my Fitbit is stuck on.
08-05-2020
21:01
10:50
08-05-2020
21:01
10:50
Thanks for your update and the picture that was attached @NaomiParker.
This is definitely not a common situation, it's the first time I see this source screen issue. What I'd suggest to fix this is our factory reset procedure. Please follow the next steps and let me know if the issue persists:
Just keep in mind that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
Please keep me posted.
08-08-2020
13:37
10:16
JuanJoFitbit
08-08-2020
13:37
10:16
JuanJoFitbit
Thank you for your help so far.
I have tried to reset my fitbit but the only button that works is the bottom right, so I can't reset it.
Any other ideas? Many thanks.
Thank you for your help. Unfortunately this hasn’t worked as the only button that now works is the bottom right and that can’t activate the Fitbit restart.
Do you have any other ideas for me?
many thanks for your continued help.
naomi
Moderator edit: merged reply
08-09-2020
15:14
10:00
08-09-2020
15:14
10:00
08-23-2020 13:29
08-23-2020 13:29
Hi - my versa is also stuck on the “source” screen - has been stuck for days and nothing I do gets it off that page. I did try the inx given for same problem to hold all 3 buttons for 10-12 seconds but nothing happened and still stuck. Help! I can’t track my exercise or see the time, etc.
08-23-2020 17:17
08-23-2020 17:17
I am having the same problem ever since I updated my Versa can't get clock or get it to do anything...
08-24-2020
02:32
11:39
RicardoFitbit
08-24-2020
02:32
11:39
RicardoFitbit
Sorry to hear that- it is annoying isnt it.
In the end nothing worked, so I kept onto Fitbit support and they put me in touch with customer support.
I also put the face into rice for 7 days to see if that would help.
I hope that helps.
Kind Regards,
Naomi
Moderator Edit: Personal info removed
08-24-2020 07:21
08-24-2020 07:21
12-16-2020 03:20
12-16-2020 03:20
I am also having the same issue with my versa 2 being stuck on the source screen.
12-16-2020 04:54
12-16-2020 04:54
12-17-2020 04:19
12-17-2020 04:19
Hi,
Thanks for this post. I updated my Versa 2 on Tuesday evening and it's been downhill from there on, with my Versa 2. Can you advise where on the back I can reset?
I'm out of my warranty too. I had to get my Versa 2 replaced in June as my previous one 'died. Literally stopped working. Not having much luck.
12-17-2020 05:41
12-17-2020 05:41
05-06-2021 17:58
05-06-2021 17:58
I am also stuck on the Source screen. Nothing that has been suggested has had any effect. Disappointed!!
05-06-2021 18:08
05-06-2021 18:08
Where is the reset button? I've tried everything else without success
05-07-2021 05:59
05-07-2021 05:59
05-07-2021 06:01
05-07-2021 06:01
05-08-2021 18:00
05-08-2021 18:00
Hi,
Do a hard reset by putting paperclip in hole on back right edge.This will reboot worked for mine.
05-08-2021 18:36
05-08-2021 18:36
I have tried the reset by sliding a pin into the recommended hole and holding for at least 10 seconds - 4-5 times - no reboot. Still stuck on the "Source" screen. Discouraging!!
