08-04-2020
09:12
20:13
RicardoFitbit
08-04-2020
09:12
20:13
RicardoFitbit
Hi there. I have been having problems with my Versa for the last 3 weeks. I thought I had solved it- by following advice on here, but now my Versa is stuck on the 'Source screen' and none of the buttons work so I can't do a factory reset or get it back to the time screen.
What should I do next?
thanks for helping me. Naomi
05-09-2021 08:20
05-09-2021 08:20
Best Answer05-09-2021 15:13
05-09-2021 15:13
My watch and phone were in proximity, but the watch was not in the charger. (Being in the charger covers up the "reset holes")
Best Answer05-09-2021 15:54
05-09-2021 15:54
Best Answer05-18-2021 09:10
05-18-2021 09:10
I am having the same problem with my versa. I was not successful with the reset button on the back. You would think Fitbit would have a solution to this issue since so many of us are having the same problem. They did have a solution foe me...buy a new watch. Looks like a will have to but it will not be a Fitbit...what a disappointment.
Best Answer05-18-2021 09:20
05-18-2021 09:20
Best Answer08-05-2021 11:54
08-05-2021 11:54
Help. Im having the sane issue. However my fitbit only has one button on the left.
Please help. Its relatively new and i dont want to replace it
Best Answer08-05-2021 12:17
08-05-2021 12:17
Best Answer08-05-2021 12:41
08-05-2021 12:41
Best Answer08-05-2021 13:02
08-05-2021 13:02
Best Answer08-05-2021 18:12
08-05-2021 18:12
Best Answer08-06-2021 06:37
08-06-2021 06:37
Best Answer08-07-2021 15:42
08-07-2021 15:42
08-07-2021 17:26
10-09-2021 08:31
10-09-2021 08:31
Try to turn on notifications from your phone and have a missed call or SMS to ur phone.
From that screen swipe down from the top where it is showing a small horizontal bar at the top
Now click on quick settings.
Source screen is coming from pressing music icon during that swipe down menu
It shows three options from swipe down
Music wallet and quick settings.
Mine worked from it
10-09-2021 16:43
10-09-2021 16:43
Best Answer11-06-2021 02:57
11-06-2021 02:57
This does seem to be a more common fault than you suggest
Best Answer06-30-2022 18:00
06-30-2022 18:00
Hey, I have the same problem, but my fitbit is Versa 2...just ONE button and it dont work... what more can I do?
Best Answer06-30-2022 19:15
06-30-2022 19:15
Best Answer09-28-2022 15:34
09-28-2022 15:34
I've had the source screen problem find a suggestion from a similar problem below are instructions:
• Unpair your Versa 2 from your phone's Bluetooth and also make sure it's no longer connect to your Fitbit app. Turnoff source screen. Turn phone off for 2 minutes. Steup your Versa 2 again.
