07-17-2021
16:11
16:29
AndreaFitbit
07-17-2021
16:11
16:29
AndreaFitbit
I did the firmware update this morning for my versa and since then it will not connect to the app. I removed the Fitbit from the Bluetooth list, restarted the phone, uninstalled and reinstalled the app but this has not helped. I am using an iPhone 10 and the iPhone iOS is current as is the version of the Fitbit app.
Moderator edit: format.
07-18-2021 07:04
07-18-2021 07:04
I hv experience the same thing now. Tried for few times but nothing change.
Best Answer07-18-2021 09:23
07-18-2021 09:23
Same here ever since I did the update I have to actually go to my phone and press sink for it to sink
Best Answer07-18-2021 11:24
07-18-2021 11:24
Same thing for me. VERY frustrating and you can't actually get help. Will never buy another product from them again.
07-18-2021 11:31
07-18-2021 11:31
Mine won’t even synch manually.
07-18-2021 12:43
07-18-2021 12:43
Update to this. I just restarted the versa and that seemed to work. To do that I had to scroll on the versa to settings then in settings go to the about menu and at the bottom of the menu is an option to shut off which I selected. After a few minutes I turned the devise back on. It took a while to restart - maybe 10 minutes but then it synced with my app.
hope this helps others.
Best Answer07-18-2021 13:24
07-18-2021 13:24
What firmware version is on your tracker??? (On the Versa - Settings, About, Version)
Thank you....
