01-30-2020 07:51
01-30-2020 07:51
Got notified yesterday my versa’s battery was low. Got to work and noticed the screen wouldn’t light up so put it on the charger. Left it all day, no charge. Got home tried the charger there, same thing, no charge. Tried to reset it nothing. Left it on the charger last night, checked this morning, no charge. Not sure what to do now, followed the instructions online on what to do if your versa isn’t charging and tried to reset it, nothing.
01-31-2020
04:04
10:07
01-31-2020
04:04
10:07
Hello @Worsley, welcome to the Fitbit Community forums.
Thank you for the information you've provided regarding your Versa that is no longer charging and that you've allowed the troubleshooting steps found in the forums.
I've gone ahead and sent your information to the Customer Support team for further assistance, so you should be getting a reply soon. Keep an eye on your inbox.
Let me know about te outcome.
01-31-2020 04:10
01-31-2020 04:10
This is exactly what happened to me as well. It worked fine yesterday. I have tried different charging blocks, chargers, outlets. Nothing works. It is dead.
01-31-2020 04:56
01-31-2020 04:56
I too am having a problem with my Versa charging. My battery was low and eventually went dead. When I got home, I charged it for several hours with no charge. I re-positioned it on the charger and left it all night. It still did not charge. I have tried everything with no success. Not sure what my next step should be.
02-08-2020 18:01
02-08-2020 18:01
Same exact problem and I too have tried various docks for charging and repositioning. Help!
02-08-2020
20:07
10:07
02-08-2020
20:07
10:07
Hello, and welcome to the Fitbit Community forums @KimEll @nursemattingly @Ginachelle8.
Thank you for confirming that you've found the same problem to re charge your Versa and that you've followed the troubleshooting mentioned earlier.
I've proceeded to send your information to the Customer Support team for further assistance as well, so you should be getting a reply soon. Keep an eye on your inbox.
02-08-2020 21:40
02-08-2020 21:40
Hi, my fitbit versa original has the same problem of not charging. My battery ran out and I tried to charge after which it is not turning on. I have tried all the things mentioned in this forum but the watch doesn't start. Please advise what should I do next.
02-09-2020 00:54
02-09-2020 00:54
I'm having the same issue with my fitbit versa. It was working fine then the battery went dead and won't charge. I've changed the charging cord, try a different charging dock, switched the electric outlet, but nothing is working. My fitbit is approximately 6 months old. Please help its the best fitness tracker I've found so far.
02-09-2020 04:14
02-09-2020 04:14
I have exactly the same problem today. Has anyone had this issue resolved yet?
02-09-2020 04:55
02-09-2020 04:55
Same here. Haven't been able to fix the problem despite following all the suggestions here. It's been a couple weeks now I'm without a working Versa Lite. Only had the watch since last summer. I received it for my b-day and don't have any receipts or other paper work in order to take advantage of warranty replacement or similar that might be available
02-09-2020 05:00
02-09-2020 05:00
02-09-2020 05:43
02-09-2020 05:43
That was the solution for me. Thanks!
02-09-2020 06:13
02-09-2020 06:13
I just had this happen to me yesterday as well what do we need to do to resolve this
02-09-2020 07:26
02-09-2020 07:26
Did not work for me.
02-09-2020 10:22
02-09-2020 10:22
Yea I had to hold the back button and bottom button until the logo appeared and then put it on the charger and it charged!!
02-09-2020 12:17
02-09-2020 12:17
I tried that and it's still not working.
02-18-2020
07:54
10:07
02-18-2020
07:54
10:07
Hello @Alif_talati @TheCaptsWife @fitonebit @Kellyp78 @Ag60, and welcome to the new users in the Community.
If you're still having trouble with the watch not charging or the screen not responding, please make sure that you've followed the steps provided in this article.
If the device is charging, but the screen is completely black, make sure that you've also completed the restart procedure described here. it seems that has been useful for other users as well.
Thank you for sharing that your watch is working properly again @Dineylynne @Liset86.
Please keep me posted.
03-04-2020 05:20
03-04-2020 05:20
I am also having this issue. I have only had the versa since aug 2019.
03-10-2020
10:02
10:08
03-10-2020
10:02
10:08
Hello @Gsheppy, welcome to the Fitbit Community forums. Sorry for the late response.
Thank you for sharing that you've been having the same inconvenience with the screen of the Versa that is not responding.
03-10-2020 12:36
03-10-2020 12:36
Mine is the same tried everything so frustrating
