06-03-2020
05:45
07:43
06-03-2020
05:45
07:43
My Versa won’t charge at all!
The pins are clean and dust free.
I have used multiple outlets to plug charger in.
It has never gotten wet.
please help!
06-03-2020 08:35
06-03-2020 08:35
I'm having the same issue!
Best Answer06-03-2020 08:52
06-03-2020 08:52
I had this last month, what had happened in my case was the versa had charged but had also tired off, which I couldn't see, I had to turn it on by holding one of the buttons in for about 5 seconds or so. I don't know if your fit bit hasn't charged or just looks that way because it has turned compleaty off, worth trying?
08:59
07:48
06-03-2020
08:59
07:48
I charged mine all night, and it said 100% so i put it on, and now its off or dead. This happend to me yesterday as well. It was on for some of the day, and then i went to look at it after dinner and it was off again.
Moderator Edit: Formatting
Best Answer06-03-2020 09:35
06-03-2020 09:35
I’m having the same problem. Had email to tell me batt low but wasn’t able to charge as was out. Screen went black. Put on to charge when I got home and nothing happened. Have tried all the methods suggested but nothing has worked 😕 only had it just over a year
06-03-2020 09:50
06-03-2020 09:50
Best Answer06-03-2020 09:55
06-03-2020 09:55
Best Answer06-03-2020 10:18
06-03-2020 10:18
Best Answer06-03-2020 10:44
06-03-2020 10:44
Best Answer06-03-2020 10:55
06-03-2020 10:55
I have a Versa 2 and I've had it a week. The second time I tried to recharge it, it failed to recharge. Now I'm attempt to reset to original settings and apply the update. I guess i'll see what happens... ugh!
Best Answer06-03-2020 12:59
06-03-2020 12:59
I had the exact same issue. Battery went to 0% and blacked out. Charged all night and nothing. Read about turning it on on note above and tried that. Nothing! Finally read help notes on cleaning and charging and tried that and let the watch charge for an hour. Then tried the reset instructions in the help pages and my watch came back to life! PTL (I had also prayed for success). Interestingly, I noted that the battery was only charged to 11% which means my overnight charging had done nothing! Apparently my cleaning the charger and watch with alcohol allowed the charging to take place so the reset option would work. As I think back over the days before dooms day, the charger was not charging the watch nearly as fast as it usually did. Maybe that's a clue that it's time to clean the electrodes? 🤔
Best Answer06-03-2020 13:14
06-03-2020 13:14
Best Answer06-03-2020 13:39
06-03-2020 13:39
Best Answer06-04-2020 23:46
06-04-2020 23:46
Still no luck 😩 when I cleaned the electrodes again it a came on for a moment saying 0% but no sign of life since then
Best Answer06-05-2020 02:00
06-05-2020 02:00
My Versa that I got 10 months ago wouldn’t charge so I tried all the steps, restart, nothing and then shut down now it won’t turn on. I can’t get through to anyone to register the problem and it is total pain. Have any of you managed to contact customer care, send for replacements etc? TIA
Best Answer06-06-2020 04:07
06-06-2020 04:07
Best Answer06-06-2020 04:50
06-06-2020 04:50
my Versa is dead... won't connect to my charger. cleaned pins and watch area.
Best Answer06-06-2020 04:53
06-06-2020 04:53
Best Answer06-06-2020 05:02
06-06-2020 05:02
Best Answer06-09-2020 13:21
06-09-2020 13:21
Hello everyone! Thanks for reporting us about the battery issues with your Versa smartwatches. We appreciate you've taken the time to troubleshooting them prior to posing here.
I'm glad to hear some of you are already back on track after contacting our Support Team. For the ones who are still working with our team I'd suggest to keep your conversation with them as they know what's the next step to try after everything you have done.
Hi @Ferretty, @SunsetRunner, and @bb.is.back, I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you soon since our support options are limited and wait times are longer than usual.
Let me know if there's anything else I may do for you.
