04-08-2021
05:30
06:36
04-08-2021
05:30
06:36
I have a versa it's a year and a half old worked great but now the bluetooth won't connect.
04-12-2021 04:15 - edited 10-10-2023 12:06
Hi there, @jenipie. Welcome on board. I understand why you're feeling frustrated.
Please note the steps recommended in my previous post can be done with any Versa Smartwatch (Versa, Versa Lite, Versa 2, or Versa 3). So, if you're having connectivity issues, feel free to try these steps.
Best Answer04-09-2021 06:36 - edited 04-26-2024 08:34
Hi there, @Spiritfilled285. Welcome to the Community Forums.
May I know the model of your mobile phone? Please make sure it meets the requirements listed here.
Despite meeting the above requirements, the following devices often exhibit compatibility issues that cause our products and services to not operate properly:
If your phone is not on the list above and meets the requirements to operate properly with the Fitbit app, please try the steps below:
1. Remove the Versa from your phone's Bluetooth settings and in the Fitbit app.
2. Restart your Versa.
3. Turn off other Bluetooth connections when not in use.
4. Plug it into the charging cable and open the Fitbit app.
5. Set up your Versa.
Best Answer04-11-2021 12:42
04-11-2021 12:42
I think the question was for a Versa, not Versa 3. I am having the same issues with my Versa and have for about the past month. I'm pretty frustrated. My Versa is 2 years old and fully charged.
