05-01-2018
19:11
05:01
AlejandraFitbit
05-01-2018
19:11
05:01
AlejandraFitbit
I've had my Versa since Saturday and I does not want to sync with my Samsung Note 8. I have done the soft reset, factory reset, uninstalled the app and reinstalled, restarted my phone and turn the Bluetooth off and on and it still wont work. Should I return it?
05-04-2018 05:03
05-04-2018 05:03
A warm welcome to the Community @Alexia-Ashford.
If you are having issues syncing your Versa with your phone, I recommend taking a look at the Having trouble syncing? post and follow the instructions provided there.
I hope this helps, let me know the outcome. ![]()
Best Answer05-17-2018 13:54
05-17-2018 13:54
Well I just say good luck to those that are trying to set up their new Versa to their Samsung Galaxy Note8 because I could not get it to ever set up and returned the product until FitBit gets their act together and it actually works for all Note 8's not just a hit and miss.
The device is one that I liked the best out of all that I have had including the Blaze, but unfortunately, this has put a not so warm and fuzzy with the Versa so far. Until it's tested and everyone is able to set up with no problems, I'll just not have a device to monitor my work.
06-18-2018 07:01
06-18-2018 07:01
Versa will not work with my Note 8 either. Very disappointed because I really want it to work.
07-12-2018 17:15
07-12-2018 17:15
Mine worked on my Note 8 until I had to do a reset on my phone because fitbit as of July 1 decided it wanted to run my battery down. Now I cant get it to sync at all. Frustrated!
07-12-2018 20:00
07-12-2018 20:00
I followed every suggestion in your link. Nothing worked. The Note 8 does not recognize that the versa exists. Not once did I even get a glimmer of connection. I'm very disappointed so much so that I don't think I'll even try a different model.
07-25-2018 11:53
07-25-2018 11:53
I just got mine yesterday and when setting it up it worked great. And now it sporadically connects. I've restarted my Note 8, rebooted my Versa, tried both at once and it's very hit or miss with this. Good thing I have 45 days to decide if I want it as right now I'm thinking it will be sent back.
09-03-2018 06:13
09-03-2018 06:13
I had similar issues. Returned the Versa after three days of trouble shooting. I'm very disappointed, but the Versa does not work well with the Note 8. (Does Samsung have any say in how the compatibility works? Do they want us to only use Samsung smart watches?) Anyway, the Versa is a great little device. I'll check back on these boards to see if there's an update/fix and rebuy the Versa.
09-03-2018 07:42 - edited 09-03-2018 07:48
I got mine working eventually.
Best Answer09-03-2018 07:47
09-03-2018 07:47
I uninstalled the app, restarted my phone, reinstalled my app and did a complete restart of the versa... somewhere along the way it connected and I've had no issues since. Trial and error of the common IT tricks and I seem to have solved my issue. Good luck to others. It's a wonderful device and I'm enjoying it a lot
09-03-2018 11:05
09-03-2018 11:05
I just got my Versa last week it took me 2 days to set it up. Well a feature didn't work so I did the factory reset like someone recommended and now it doesn't see my phone or tablet. I have uninstalled and reinstalled the app so many times as well as tried other things. Now I can't even turn off the watch like someone recommended. Sending mine back tomorrow because I am so frustrated and disappointed with it!
Best Answer09-03-2018 14:41
09-03-2018 14:41
09-26-2018 14:20
09-26-2018 14:20
I am not really sure. But happy to see your message that it still isn't fixed. That's too bad, because I really love the look of the Versa. Fits a small wrist and doesn't look overly big like the Blaze I had. I was almost going to go get another one, but guess I'll search other avenues and see what's out there. Samsung watches to me are way too big for my wrist, but don't think they're controlling it. Other Samsungs work just fine - just not the Note 8's.
10-15-2018 06:37
10-15-2018 06:37
Thank goodness I'm not the only one having this problem.
I bought the Versa 3 days ago and I've been with Fitbit support 4 times each time for more than 30 minutes.
I am fond of this Versa, it's just too bad it would never sync. Time to return it.
Best Answer10-23-2018 17:54 - edited 11-27-2018 20:55
UPDATE 11/27/2018 1 month after posting below, I’ve not had one single time it’s not synced!
After months of cussing, I convinced my Versa to sync with my SN8 by turning off other Bluetooths in the vicinity (specifically my iPad). It was that simple for my problem.
This time I didn't do anything to my SN8. [I didn't soft/hard restart anything, charge anything, clear any caches, uninstall/reinstall apps, goof with my SN8's Bluetooth settings, or anything else]. I just turned off the iPad's Bluetooth (it might be worth noting that the "all day sync" option in my phone's fitbit app is set to on).
I went to the fitbit app on my phone, told it to sync, and it synced. I exited the app on my phone, opened it, and it synced again - all by itself! It hasn't done that since I can't remember when!
I checked my SN8's Bluetooth to make sure it was paired with the Versa. It is paired, but oddly, it doesn't show that it's connected. The SN8's Bluetooth scan says the Versa can't be found. Even though it doesn't seem to be connected, I returned to the app, told the app to sync again - and it did!
10-25-2018 07:12
10-25-2018 07:12
Hello everyone, I hope you're doing well. ![]()
I appreciate your participation in the Forums and for letting us know you're still experiencing these issues related to your Versa not syncing. At this moment I would like to gather some information from you so we can determine what we should do next.
If you have already contacted our Support Team, my best recommendation is to keep working with them as they will have more options to share with you. For those who haven't contacted our Support Team, I'll be waiting to hear form you.
Thanks for your patience and understanding, I hope you have a great day.
Best Answer10-28-2018 05:40
10-28-2018 05:40
Best Answer11-27-2018 08:54
11-27-2018 08:54
I had better luck going to the Versa page and syncing from there versus syncing on the dashboard, but you're right, this is ridiculous. I've had two Surges, a Blaze and now the Versa, and without question this device is the most difficult to sync.
Best Answer11-28-2018 07:32
11-28-2018 07:32
Hello @Clevelandusa, thanks for joining the conversation, it's great to have you on board. It's nice to see you around too @humpfh, I hope you're doing well. ![]()
I appreciate you have taken the time to let us know the troubleshooting steps you've tried so far and for sharing your experience with us. As previously mentioned, I would like to gather some information from you so we can determine what we should do next.
Thanks for your patience and understanding, we'll be waiting to hear from you.
Best Answer11-29-2018 08:00
11-29-2018 08:00
I have had nothing but trouble trying to connect and receive notifications on my Versa. Has the same trouble with the charge 3. I sent it back and and Sending my Versa back. I love my Blaze but it is dying a slow death. I have to charge it every 2 dats or so. But other than that it operates flawlessly!!
