10-05-2019 06:45
10-05-2019 06:45
Hi everyone I cannot turn on my Versa... I went swimming and it switched off then I turned it back on and it was good but an hour later my watch switched off again. Has anyone had this issue before ?
10-06-2019
11:18
06:58
10-06-2019
11:18
06:58
@Ophelie Welcome! It's nice to have you on board!
Let me help you with your Versa not turning on. Try cleaning the contacts using cotton with rubbing alcohol then charge it by plugging it for a couple of hours directly to your computer's usb port (try different ports) or use an UL listed usb wall adapter. After this, restart your device and see how it behaves. You can also find additional suggestions here.
Let me know how it goes.
Best Answer10-06-2019 14:41
10-06-2019 14:41
I had the same issue with the ionic and apparently it is completely dead (17 months old). I tried cleaning it as stated but still won’t charge. I was considering getting the Versa but think it might be best to move on from Fitbit as their products don’t appear to last.
