06-15-2020
09:08
12:43
06-15-2020
09:08
12:43
I went to bed with my versa on and it was at 52% battery. When I woke up, it wouldn’t turn on at all like it was dead. I put it on the charger for about 2 hours and still nothing. In the Fitbit app, it cannot detect my watch. I have tried resetting it by holding down the buttons but still nothing. Has anyone experienced this and found something that works?
06-18-2020 04:44
06-18-2020 04:44
Hello everyone!
We acknowledge the limitation we have on our part particularly on what you have experienced. We‘re taking into consideration your comments and sentiments with regards to our products and services.
I've seen the majority of you have contacted our Support Team, so my best recommendation will be to keep the conversation with them as they'll know what the next step to try based on your warranty status and your specific issue. Discounts and replacements depend on tracker model and other factors.
Hi @aliebendixen, welcome on board. Thanks for the details provided about what happened to your Versa. Please refer to this post for troubleshooting steps. Make sure to check them out and let me know if the issue persists. If such is the case, my best recommendation will be to get in touch directly with our Technical Customer Support department here. I would also contact them on your behalf if necessary, just mention me and I'll move forward with the request.
Hello @Tcole53, thanks for stopping by. If you cannot longer get any help from Best Buy, please let me know so I can forward your concern to our support team so you can get further help.
I'll be around, keep me posted.
06-15-2020 11:31
06-15-2020 11:31
The same thing happened to me today. My watch was at 92% before I went to bed and now nothing is working. I tried everything and nothing happens. I just got my watch yesterday. Any help would be greatly appreciated.
06-15-2020 12:40
06-15-2020 12:40
same thing is happening to me. When going for help it only goes to this forum.... is there a number we can call or email or something? I have even tried plugging into different blocks and different outlets in the house. My fitbit app says the battery is empty? I've been charging it all day but there is no charge:(
06-15-2020 12:53
06-15-2020 12:53
Hi there @SunsetRunner, @andrea_iazzetto, and @BDonn, welcome to the Community Forums. Thanks for the details provided in your posts and for taking the time to troubleshoot your Versa smartwatches prior to posting here.
The battery on your watch may not be charging properly and therefore does not turn on or even is causing a battery drain. I recommend that you follow these steps:
Please check the steps recommended above and let me know if the issue persists. If such is the case, my best recommendation will be to get in touch directly with our Technical Customer Support department here. Also, I can contact them for you if necessary, just mention me and I'll move forward with the request.
Let me know how it goes.
06-15-2020 12:59
06-15-2020 12:59
My versa went black today was fine this morning 90% battery stopped around 1
pm EST. I’ve had this versa for 19 months with no issues.
I tried the 3 button reset with no results.
I’m also looking for any helpful advice.
06-15-2020 13:07
06-15-2020 13:07
Same thing for me, happened yesterday. What is going on?? It was charging day before with no issues and now my charger is picking up but only displays 0% briefly; battery was not at 0 when it died either. Does not respond to any reset buttons either. Are we just out of luck??
06-15-2020 13:24
06-15-2020 13:24
I am having the same issue. Fully Charged my Fitbit last night and it started vibrating and ‘acting crazy” all of the sudden today. Then it turned off and I cannot turn it back on.
06-15-2020 14:13
06-15-2020 14:13
06-15-2020 14:32
06-15-2020 14:32
I just did a chat with support and after the basic troubleshooting with no luck, they offered me a discount on a new device so I guess ours are done. I asked if this was a known issue since others are reporting and didn't get a reply directly to that question. Good luck
06-15-2020 14:37
06-15-2020 14:37
Well I’ve tried the help chat got kicked out of the system while waiting three times.
Finally got to an agent she dropped the chat while I was typing my question.
chat is now full won’t open.
Now holding on the phone...
06-15-2020 14:42
06-15-2020 14:42
Wow.. they must be really busy!
06-15-2020 15:08
06-15-2020 15:08
I'm with you. Really annoying! I tried to take the udpate and it kept failing. Missing a firmware update should not wipe out the device. I totally agree a warning would've been nice. Do you think you'll get another Fitbit?
06-15-2020 15:16
06-15-2020 15:16
The same thing happened to me. My Versa 2 was working this morning - did a spin class and logged it.
Then shortly after the fit bit logo came on the screen then it went blank.
I held in the button and it looked like a computer screen going haywire then went dead.
At one point it showed NO battery (The battery icon with red and a Red Explanation point) But I know it was at 40 percent battery life because I charged it before my spin class.
Is this a FITBIT outage issue since so many people are reporting this? My fit bit is only 6 months old -help, I am lost without it!!!
06-15-2020 15:24
06-15-2020 15:24
06-15-2020 15:26
06-15-2020 15:26
Plugged in my two-year-old Versa over the weekend and it didn't charge - in fact it was now totally drained. My wife got me two new chargers, neither worked. I've cleaned the contacts on the watch but that doesn't appear to have helped. The best I get is a brief red display of 0%. I tried the USB port on my laptop and that doesn't help either. I liked the Versa, but if it's only good for two years at what it costs, I'm not sure I'd be inclined to buy a new one. So short of replacing it, is there anything I can do to fix this?
06-15-2020 16:00
06-15-2020 16:00
06-15-2020 16:08
06-15-2020 16:08
Similar thing happened to my. Had my Versa for about 18mos. Was working fine until the last week. Over a few days it started draining the battery quickly, vibrating, doing weird things. The heart rate stopped working. I restarted it several times. At one point I put it on the charger and it wouldn't charge. Pulled it off and put it back on and then it worked. Yesterday decided to do a factory reset. Seemed OK, but HR still didn't work. This morning battery was low again, put it back on the charger. Now the screen won't come on at all. It still seems to be working, it will vibrate, if I try to hold down the buttons for a restart the screen will get brighter, but still not display anything. Oddly, it still seems to be tracking steps.
06-15-2020 17:45
06-15-2020 17:45
Just purchased my versa 2 today. Began setting it up. Appeared to began syncing to my android as I saw my steps count. Then the versa went black. I cannot get it to come on or light up at all now. I plugged it into a good power strip. Still nothing for the past few hours. Isn't it supposed to light up while charging? It is not the outlet because the lamp works. Can someone help me
06-15-2020 18:01
06-15-2020 18:01
06-15-2020 18:16
06-15-2020 18:16
