05-02-2024 17:58 - last edited on 05-03-2024 06:57 by MarreFitbit
I tried everything and after 10 years with Fit-bit and dealing with all the problems, I'm outta here.
05-02-2024 23:02 - edited 05-02-2024 23:07
Hi @Spider1959 - just in case the watch is ok did you check this link How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
Normally the screen will come on when charging starts but if not when charged for 2 hours try holding the button a few seconds to start it manually otherwise.
Also in the Fitbit App, sync and check the battery level, this will verify if the watch is working and charged but it's display is broken.
If the watch is dead it won't sync, but if it does sync you can also try changing clock face from the app.
05-07-2024 04:47
05-07-2024 04:47
It's DEAD, I've moved to Garmin
