01-30-2020 12:00
01-30-2020 12:00
I'm one of those hundreds of people whose brand new Versa 2 doesn't work properly after the update. Fitbit offered me a replacement, which is cool. However, then I didn't hear anything more from them. No update, no tracking number. When they replaced my Alta (after another update mess up, which didn't fix the problem, so I moved to Versa..) I had an email that it had been sent the next day.
Conversations with Fitbit just tell me to wait a bit longer, my custom is important, and they are waiting for a resolution from "the special team". I've asked what exactly the problem is, but no direct response to direct question.
Do they not have enough fitbits? are they prioritising new fitbit buyers over replacements for those who have already bought them? I really don't mind waiting for it, if only they would b upfront and tell me what's going on, and give me an estimate of how long it will take.
01-30-2020 12:11
01-30-2020 12:11
Mine is not working properly either , none of the apps work. Ive tried every trick listed to sync or reboot, even factory reset! I cant find any answers , no help anywhere! who did you contact?
Best Answer01-30-2020 12:39
01-30-2020 12:39
Best Answer01-30-2020 16:38
01-30-2020 16:38
Hi @Wendra Here is the link for Customer Support
Helen | Western Australia
Best Answer01-30-2020 17:05
01-30-2020 17:05
