02-09-2020 08:39
02-09-2020 08:39
My Fitbit Versa 2 came set up with a required 50 steps at 8:30 everyday. So each morning when it goes off I have to walk 50 steps regardless of what I’m doing. I can’t seem to find a way to turn it off altogether or stop it from vibrating when it does go off short if taking the required steps.
Help?
02-09-2020 11:05
02-09-2020 11:05
Strange I've never seen this one before. Are you certain this isn't part of the current clock face (if its a 3rd party one)? Have you tried changing to a different clock face. That's the only thing I can think of, as this definitely isn't a stock (out of the box) feature.
Best Answer02-09-2020 08:56
02-09-2020 08:56
Hi @Ross009, welcome to the community.
I think you are talking about reminders to move?
Have you tried opening the Fitbit app on your phone - tapping your profile picture (top left corner) - tap on Versa 2 - scroll down to reminders to move. You can't then turn this off using the toggle, or change the hours that it's in effect.
Best Answer02-09-2020 08:59
02-09-2020 08:59
Thanks for the reply! Unfortunately that’s not the issue. I’ve turned those off. This is one that was preset when I purchased it. The “50 steps at 8:30” is actually a permanent display on my watch face! So annoying.
Best Answer02-09-2020 11:05
02-09-2020 11:05
Best Answer02-09-2020 12:58
02-09-2020 12:58
Great idea! Just tried deleting that face and using a new one. Guess I’ll find out tomorrow at 8:30. So appreciate the suggestion. Thank you.
02-09-2020 13:02
02-09-2020 13:02
No problem, if you could update us with the outcome that would be great.
Thanks.
Best Answer02-10-2020 21:41
02-10-2020 21:41
Yep! That did it. It was a third party watch face that came with it set. Thanks for your help.
Best Answer02-10-2020 23:56
02-10-2020 23:56
No problem, thanks for confirming. Glad everything is working now.
