12-30-2019
01:03
04:38
DavideFitbit
12-30-2019
01:03
04:38
DavideFitbit
Downloaded new face with steps, battery level, heart rate etc but sometimes face will show correct image but mostly shows a grey analogue clock with icons of steps etc
Moderator edit: format
12-30-2019 03:17 - edited 12-30-2019 03:21
Hi @JudeSherlock1, welcome to the community.
I think you may be describing the always on clock face, which is a lower power version of the selected face (often minimal elements and icons, and lower brightness). Is your clock face on all the time?
You can disable the AOD (always on display) by swiping to the settings app on your Versa 2 and tapping it - scroll down and tap on always on display - toggle between on/off. If you do set it to off, be aware the display will turn off unless you have raise to wake on or you press the button to wake the display.
You might find the following help article useful (here), it explains the AOD a little better.
Best Answer12-30-2019 03:17 - edited 12-30-2019 03:21
Best Answer12-30-2019 03:20
12-30-2019 03:20
Thankyou Nathan, tried that & yes it works perfectly
Best Answer12-30-2019 03:22
12-30-2019 03:22
Great, you should also have much improved battery life with the AOD disabled.
