Add a feature that prevents overchargeing in fitbit versa 2, versa series and on all fitbit watches if possible. So in the fitbit mobile app (or watch setting) Allow the user to enable/disable overcharge protection, use fitbit recommended battery percentage (uses less cycles in the battery and generally last good) for battery protection.
Community Guidelines
Learn the Basics
Join the Community!
Go to the Help Site
Contact Support
