01-04-2023 07:06
01-04-2023 07:06
2 week old Sense 2 plugged in for 30 mins. Battery gone DOWN from 15% to 6%. And it just keeps buzzing with a message about setting up alexa.
Pleasa help
Best Answer01-04-2023 09:32
01-04-2023 09:32
Hi @MaireC - it could need cleaning or the charge cable is faulty, see things to follow in How to check charge cable - Sense/ 2Versa 4 won't charge, won't start or blank screen
If it is busy and likely not charging that could explain the rapid drain.
When it's working again, in watch Settings disable the voice assistant for long press to stop that Alexa setup coming back/
