01-09-2021 12:56
01-09-2021 12:56
I use my Fitbit Sense to track my exercise and sync it to Strava. Unfortunately, it always seems to grossly underestimate my km. The funny thing is that the map that the GPS draws in Strava is quite accurate. Is says km in my data measurements, but the distances the Fitbit is recording would actually be pretty accurate if they were miles (the Fitbit definitely says km). I'm wondering if there is a setting somewhere that I need to change?
Best Answer01-09-2021 21:53
01-09-2021 21:53
@KareBear7811 can you pls share a screenshot of the workout recorded by sense? With map and all.
Best Answer01-10-2021 05:15
01-10-2021 05:15
Sure. How do I share a screen shot here? I don't see any way to do that.
Best Answer01-10-2021 05:49
01-10-2021 05:49
Okay, I think I may have figured out a way. The screen shot is here:
https://drive.google.com/file/d/1iDwqpXMan44xsrRhT2vS_yoGGpfjc83T/view?usp=drivesdk
Best Answer01-11-2021 18:30
01-11-2021 18:30
What I notice is that my distance in the Fitbit app is set to 4.5 miles, but on my Sense under Core Stats, it shows up as 7.24 mi (which happens to be what 4.5 miles convert to in km). Any fix from the developer on that?
