02-14-2024
06:18
08:47
RodrigoMFitbit
02-14-2024
06:18
08:47
RodrigoMFitbit
My Fitbit sense has a picture of a battery and says 0%. Does that mean my watch is dead?
02-14-2024 08:46
02-14-2024 08:46
@Bonnie225 Welcome to the forums. Thanks for reaching out about your Fitbit Sense.
That is the symbol the device displays when the battery is empty. This means you have to connect it to its charging cable and let it sit there until it is full. The display will show you the battery percentage. I recommend you take a look at this article: How do I charge my Fitbit device?.
Best Answer02-14-2024 09:06
02-14-2024 09:06
I charged it. Yesterday. I had it on the charger for 3 hours still nothing does that mean my sense is not working anymore or do I need a new charger
02-14-2024 10:18
02-14-2024 10:18
@Bonnie225 Thanks for the swift reply and explanation. In this case please be so kind to try the tips outlined in this help article: Why isn't my Fitbit device's battery charging?. Several factors come into play. Give all tips a try! Thanks in advance.
Best Answer02-18-2024 19:51
02-18-2024 19:51
Hi @Bonnie225 - did you resolve your issue, if not see How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
Best Answer02-18-2024 20:36
02-18-2024 20:36
Best Answer02-24-2024 09:35 - edited 02-24-2024 09:36
FitBit "moderation" seems to have removed all replies that were actually useful...
Anyway, I had the same problem, it took hours to do a "factory" reset (download was very slow and failed multiple times) but eventually it worked.
You have to press the button while on the charger until you feel it buzz, then release and press again.....or something like that.
