06-09-2022 00:42
06-09-2022 00:42
My Sense has had low battery life for some time now and now it won’t charge. I’ve had it charging since 11 pm last night. I’ve tried different USB ports, a wall charger, and even cleaned the back of my Sense. What do I do now?
00:53
11:03
06-09-2022
00:53
11:03
Hi @Sweethaven - it may need more thorough cleaning or commonly the charge cable is faulty - see all instructions in How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
If you need a new cable you can get them from Fitbit under warranty or buy them online.
06-09-2022 17:52
06-09-2022 17:52
It's possible the pins on the charger are at fault. They tend to fail all too often.
