12-04-2021 22:44 - edited 06-17-2022 01:35
If you set the temperature in the Fitbit App [profile photo => App settings => Units => temperature] and you are still not getting the degrees in Fahrenheit or Centigrade as you have defined it, it is because the Weather app has its own settings.
To fix the temperature degrees for Weather:
In the Fitbit App click
Then sync the watch.
For weather showing directly on the clock face there may or may not be a clock face setting to change.
If it is still a problem,
for more information see How do I set up and troubleshoot apps on my Fitbit device?
10-22-2022 09:51
10-22-2022 09:51
THANK YOU!!!! I would have never figured this out… and heaven knows I’m too stubborn to learn the metric system.
WOULD HAVE BEEN NICE IF FITBIT COULD HAVE BEEN ABLE TO OFFER THE SOLUTION!! 😠
12-30-2022 06:14
12-30-2022 06:14
THANK YOU SO MUCH! You clearly and succinctly explained how to fix this ongoing problem. And the solution worked! Truly appreciated!
01-12-2023 14:08
01-12-2023 14:08
There's no Weather component in the iOS app. When I do find Units, it's already set to Fahrenheit, but Celsius is showing on my device. The weird thing is that it showed Fahrenheit yesterday.
I refuse to call in, as I have yet to speak to a customer service rep that knew what they were talking about.
Best Answer01-12-2023 14:16
01-12-2023 14:16
Changing the units in the Fitbit app doesn’t affect the settings in the weather “sub app” (if you will) you need to go deeper in the gallery and find the weather sub app and change the units in there. The weather sub app must be in the gallery or you would not have any weather information on your watch.
01-12-2023 16:14
01-12-2023 16:14
Hi,
Appart from what @wjbertrand suggested, which by the way is the solution, you might want to make sure that the weather app under the gallery has full permission to your location on the phone to ensure an accurate result. I recently switched to iPhone and it works ok.
hope this helps.
01-12-2023 21:07
01-12-2023 21:07
Hi @dwilliamhood - please follow the instructions in the first post which describes where and how to fix it.
03-11-2023 10:46
03-11-2023 10:46
Guy. Thank you so much that's worked a treat ☺️👍
03-11-2023
11:30
06:40
03-11-2023
11:30
06:40
04-11-2023 19:22
04-11-2023 19:22
Thanks that did it!
07-03-2023 14:26
07-03-2023 14:26
My Hero! 🤗
Thank you Guy 1956 that worked perfectly! I had just about given up.
You'r a genius and I am soooooooo happy your responded to my request.
Thank you also for the step by step guideline.
May you be blessed with your most desired wish. 😀
