06-07-2021 17:46 - edited 06-28-2021 11:19
Hi there,
Our team has released the new Fitbit iOS App 3.43 version and it should be available for all of you. Please make sure to download it from the App store as this will resolve the battery short life issues experienced on your Sense. Take in mind that this and future Fitbit app versions will require iOS 13.4+.
Hi everyone. Thanks for your continued reports.
Our team is aware of the Sense not holding charge when syncing with iOS devices and they're working to bring a fix as soon as possible. In the meantime, we recommend force quitting the Fitbit app on your iOS devices to prevent the battery from draining when syncing.
I've moved your posts to this thread so we can keep our team informed of this situation. Your patience is truly appreciated and please know your feedback hasn't gone unnoticed.
See you around.
05-07-2021 12:11
05-07-2021 12:11
Same with me, it is an IOS issue, i was told by Fitbit. Nothing can be done until they resolve the issue, IM NOT HAPPY.
05-07-2021 16:44
05-07-2021 16:44
Best Answer05-07-2021 16:49
05-07-2021 16:49
Thanks for letting me know, i will call again and hopefully this time i will be getting a positive answer!
Best Answer05-07-2021 21:19
05-07-2021 21:19
05-07-2021 23:50
05-07-2021 23:50
Hi LizzyFitbit,
I’ve been continuously mailing with the fitbit team for almost a week now. Still no solution for my draining problem 😥.
I’m convinced the problem is the Fitbit app on my iphone and not my Fitbit Sense it self. As soon as I turn off Bluetooth on my iphone the battery drain stops. The issue started when I updated the Fitbit app.
The Fitbit team won’t (can’t?) inform me about the cause. They only tell my what steps to follow in order to investigate the matter. Untill now unfortunately unable to fix the issue.
Greetings,
Roel
05-08-2021 04:37
05-08-2021 04:37
Interestingly, I have tried testing your theory and I think you are right. At 10:30 this morning I was at 100% by 11:30 I was at 95%. I have turned off the Bluetooth on my Iphone and in the last hour I have only lost 1% of my battery. Last night I had 100% battery at 19:00, in the middle of the night my battery died. Something is clearly wrong. I haven't changed any settings on it since I received it at Christmas and I used to get at least 5 days out of it, yesterday I charged it 3 times to get through the day.
05-08-2021 05:55
05-08-2021 05:55
I have logged a call, their response was to send me to the article about what causes battery drain. I'm not doing any of those things and when I lost 5% in an hour I was sat watching TV.
I have done what Roel_kokonut suggested and turned off my Bluetooth and in the last 2 hours have only gone down 1% while I have been out working in the garden.
Customer support is sending me a label to return my Sense for a new one. Not sure that will correct the issue.
05-09-2021 01:33
05-09-2021 01:33
I have had nothing but problems with my sense. Firstly it wouldn’t sync intermittently, then it stopped syncing altogether. Finally got it resolved, now the battery drains overnight in 8 hours and nothing has changed on my watch to make this happen. Fitbit take days to answer emails which isn’t good enough. It’s 8 months old no doubt they’re waiting to the warranty expires!!! Crap watch don’t buy.
05-09-2021 01:45
05-09-2021 01:45
I have the same problem but now on my case my battery drains within 4hours of fully battery charge! I haven’t changed any settings since I bought it in January. It’s frustrating
05-09-2021 05:00
05-09-2021 05:00
This issues has started for me too in the last 24hours
i wonder if it’s an update issue
05-09-2021 05:10
05-09-2021 05:10
My sense is 3 months old and all of the above has happened. I’ve always loved my Fitbit’s. The sense seems to have problems. I did a chat with customer service and they are sending out a new one. Currently my sense drains in 4-6 hours 🥺
05-09-2021 14:13
05-09-2021 14:13
Update: I sucked it up and did a factory reset. I held off on this, thinking it'd be a huge inconvenience, but it wasn't. Since I've done the factory reset, things seem to be working all as before. The Fitbit team did reach out to me to replace my device, but since I did the factory reset and things seem ok, I asked they keep the ticket open just to make sure it sticks, but I'm ok as of now. I still think there was a factory/coding issue associated with these troubles, but it seems the factory reset fixed the problem.
05-10-2021 02:36
05-10-2021 02:36
I wonder the same thing and it has been an issue all weekend. In the past, my sense's battery life has been 7 days..
05-10-2021 04:29
05-10-2021 04:29
Effectively its a fault with the IOS Fitbit App.
The workaround for now is to turn Bluetooth off on the phone and to charge and restart the watch.
05-10-2021 06:03
05-10-2021 06:03
Did you also remove the Fitbit app on your phone?
05-10-2021 06:15
05-10-2021 06:15
I have Android and am seeing the same issue, but restarting the watch seems to fix it for a while.
05-10-2021 07:41
05-10-2021 07:41
05-10-2021 08:35
05-10-2021 08:35
Same problem of battery draining started for me about 5 days ago when for the last 5 months I have had a weeks worth of battery. I have also tested through turning off bluetooth - fully charged fitbit and then switched off bluetooth for a few hours, went for a GPS tracked run during that time and only lost 12%. Switched bluetooth back on and within next couple hours it was down to 37%. Definitely all happened since the app update last week, so assume that there are some syncing issues with the app that is draining the battery.
05-10-2021 08:59
05-10-2021 08:59
Got my Sense in March. It has regularly lasted 5 days. Suddenly on Saturday it went from 100 to dead in less than 8 hours. Followed all the tips to manage batter life and it died again yesterday in less than 8 using no apps, all battery life extending settings. Fitbit, what gives? You could be honest and let us know of buggy updates. Is it faulty batteries? This is a major issue. We can’t all be doing the wrong things all of a sudden.
05-10-2021 13:07
05-10-2021 13:07
Same here wouldn’t sync on weekend restarted, re-set, deleted app started again eventually synced last night after update was on 77% when I went to bed was flat this morning!! Usually it last 5 days
contacted Fitbit who were no help!!!
