06-01-2021 06:51
06-01-2021 06:51
Everytime I charge my Sense it goes into an infinite loop, "it displays the charge level, then the home screen and then the message that it can charge faster if plugged into a faster charger with a big Orange OK and finally screen goes dark" it repeats this every 30 seconds. Oh did I mention that it vibrates too every 30 seconds. Reviewing the PDF manual there is no mention what charging speed or type is needed. I have so many different chargers, like the Samsung adaptive charger that can charge at either 5 volts or 9 volts. For such an expensive Fitbit you think you would provide the best charger for the Sense. This is a new event. This charging experience didn't happen a month ago. Now I have to charge the Sense in a room that I'm not in so that repeating loops don't piss me off so much.
06-02-2021 01:16
06-02-2021 01:16
It would seem the watch is either dirty or the charger is not making good contact, a common problem.
Best to try connecting to a PC and see what sounds the PC makes. A single recognition of a device is good, repetitive connections is a faulty connection with the watch.
As your watch is under warranty probably best to contact Fitbit Support directly. They may be able to help you with a replacement charger if necessary.
