11-07-2020
14:24
10:37
EstuardoFitbit
11-07-2020
14:24
10:37
EstuardoFitbit
I just finished setup of my sense on an iPhone 11 and the only notification that I received are txt messages. No other notifications appear on the watch but display like normal on phone.
I am able to answer calls get txt message but that’s it. What can be done to correct this issue?
Moderator Edit: Clarified subject and updated label
Best Answer11-08-2020 17:36
11-08-2020 17:36
Hi @Stubborn1. Welcome to the Community Forums. @meresydotes and @Rich_Laue, thanks for stopping by. Your posts are very helpful!
@Stubborn1, thanks for your efforts while troubleshooting your Sense, as well for checking the App notifications settings on the Fitbit app. While it's odd only the call and text messages notifications are working, give a try to the following steps:
Let me know how it goes.
11-07-2020 17:47
11-07-2020 17:47
Did you setup your app notifications? I'm not familiar with iStuff, but on Android, you have to separately setup notifications for your apps. I believe it's in roughly the same place as the call/ text notifications.
11-07-2020 17:51
11-07-2020 17:51
Have you looked under the App Notifications and enabled the apps that you want to receive on the wrist?
11-07-2020 20:24
11-07-2020 20:24
I have. Even deleted my old versa in case there was a conflict of systems.
Best Answer11-07-2020 20:26
11-07-2020 20:26
I did verify
11-08-2020 17:36
11-12-2020 00:01
11-12-2020 00:01
Hi @LizzyFitbit
Using step 6 and making adjustments within the notification section here allowed me to receive my notifications on my sense. I had to activate the toggles.
Thank you.
11-13-2020 09:12
11-13-2020 09:12
Hi @Stubborn1. I hope you're doing well.
Thanks for keeping me updated and I'm glad the steps posted above helped you to receive App notifications on your Sense. This is great news and I hope you continue enjoying the Fitbit experience. By the way, check out our Health & Wellness board where you will find great tips and encouragement from other members.
See you around! 😊
