04-01-2021 05:29 - last edited on 04-05-2021 17:01 by LiliyaFitbit
I just set up my fitbit yesterday and I am not getting any Sp02 readings?
04-05-2021 16:59
04-05-2021 16:59
Welcome to the Fitbit Community, @lauren0711.
Thanks for the details shared in your post. I understand your concern and recommend following our tips in Why didn’t I receive SpO2 data?
By the way, I've moved your post to Sense board so we can keep our forums organized.
Hope this helps.
Best Answer04-05-2021 16:59
04-05-2021 16:59
Hope this helps.
Best Answer05-02-2022 06:05
05-02-2022 06:05
The same thing is happening to me. Brand new Sense set up 6 days ago and worn pretty much 24/7. All other health metrics but not SOo2.
Best Answer05-02-2022 13:57
05-02-2022 13:57
Mine showed it for a while, but has stopped.
Best Answer05-02-2022 16:30
05-02-2022 16:30
First off, do you get an SPO2 in "Today" on your watch? (ie is not taking a reading, or not syncing). Restarting the watch is only thing I have found that improves things. My wife does it pretty regularly. Mine usually works.
Best Answer05-02-2022 17:55
05-02-2022 17:55
Have you made sure that the SpO2 is enabled? Shutdown the tracker?
Do you get sleep stages reported?
Best Answer05-03-2022 19:26
05-03-2022 19:26
Thanks to everyone that made suggestions. Not sure where I saw this but I found content somewhere saying I should install the SpO2 app in the Fitbit App gallery and when I did, I started getting SpO2 readings. Problem solved.
