08-14-2022
17:10
05:46
EstuardoFitbit
08-14-2022
17:10
05:46
EstuardoFitbit
I’ve been letting this charge for an hour and a half. I’ve tried a different outlet and a different box. It shows no signs of life, doesn’t vibrate when I press and hold the button
Best Answer08-14-2022 19:34
08-14-2022 19:34
Hi all, it could be as described in this article How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
08-14-2022 18:45
08-14-2022 18:45
I am having the same issue. I tried cleaning it how they suggested and it's still not charging.
08-14-2022 19:34
08-19-2022 15:29
08-19-2022 15:29
I have cleaned the sense, got a new cable and it won’t charge.
05:54
10:01
08-20-2022
05:54
10:01
HI @MrsRobson71 - wiping the watch might not be sufficient, pay careful attention to the 4 holes on the back of the watch, they are prone to getting dirt in them. How do I clean my Fitbit device?
Also check the new cable is not already faulty as well.
Best Answer08-20-2022 07:30
08-20-2022 07:30
It’s a new cable. How can I check if a new one is covered by warranty?
07:51
10:00
08-20-2022
07:51
10:00
@MrsRobson71 - if you purchased a new cable you have rights.
But check first if it is faulty using the link already provided in this topic
