02-23-2025 07:14 - edited 04-06-2025 01:06
There is an issue with the step counting as shown here, with the dated Core Stats.
At 15:38 the watch was indicating an erroneous 13,256 steps
After a sync it was showing a more accurate 8,536 steps
How or why this bug has appeared is unknown. It is due to improper syncing/server processing.
There is nothing a user can do to fix this bug, any attempts could make matters worse and be a waste of time.
If the watch is not connected to the Fitbit App, by closing the app [often not possible] or better by turning off Bluetooth, and the steps are correct it would confirm that as the cause.
For Versa/Sense users [not Versa 4 or Sense 2], the SimpleCheckUp app [first screen] might help to know on the watch when the watch last synced.
When turning on Bluetooth again, it is necessary to manual sync a few times to get the correct steps to show.
This bug is NOT related to any watch firmware update or Fitbit App update and applies to all phone and watch types. There will be no update issued to fix it.
Steps counting bug - Update March 20th
It seems this is still not entirely stable and Google may still be introducing changes.
Small adjustments can appear when auto syncing [every 15 minutes about depending on connectivity] or even manual syncing randomly.
Steps counting bug - Update March 19th
After some more testing and in the absence of any official information from Google - the app finally appears to sync correctly without any unwanted adjustments.
Of note, no action by the user was/is necessary for the syncing to be correct, as the error was only at the Google end.
Steps counting bug - Update March 17th
Some people still noticed minor adjustments to the watch steps when syncing, meaning the problem is still not fully fixed.
Steps counting bug - Update April 7th:
The ensuing minor steps adjusting bug that was still prevalent seems also fixed now.
Steps counting bug - Update March 13th:
This may finally be fixed - check steps on your device and manually sync, If the app then shows the same for you it is fixed. However some minor adjustments still seem to occur.
Stress Management Score - Update March 7th:
The missing Stress Management Score that affected all user types [regular or premium] is supposedly fixed now without any user intervention. Though the missing history is not recovered.
For those still not getting it yet please make a separate post/investigation.
yesterday
yesterday
