02-10-2017 02:33
02-10-2017 02:33
my surge stop to cync to my phone. try to pair again after unpair it on the phone. Now the phone can not find the tracker. Say no nearby device found. Screen on the tracker stay on Pair. have uninstall the app and install again. Have turned of phone and tracker and restart again. also tried another phone. Seems the problem is with the tracker.
02-10-2017 04:10 - edited 02-10-2017 11:05
Hey @Paulth! Welcome to the Forums. It looks like you've been trying a lot of steps. Well, let's see some details that maybe you already checked but it's worth it to ask. Which model of phone do you have? Is it up to date? If so, I'd suggest restarting your Surge a couple of times in row. Then follow this steps. I think the same way, your phone is doing his best but the tracker is not responding.
If after doing this again, your Surge is still not connecting properly; please contact a Fitbit representative, so they can futher investigate.
Keep me posted! ![]()
Best Answer02-10-2017 09:12
02-10-2017 09:12
I am using a galaxy 7 edge. The surge connect to it previously. Latest softwares were done on both
Best Answer02-10-2017 09:53 - edited 02-10-2017 11:05
Hello @Paulth, thanks for your quick reply and for the details of your phone. Did you try the steps suggested above? I was thinking in trying those steps also in different device, if you have that option; or in a computer. Is this possible? Restarting your Surge should be key in this process! Try do so, at least 3 time in a row and let me know how this works. ![]()
I hope this helps, I'll be around! ![]()
Best Answer02-13-2017 06:57
02-13-2017 06:57
Fitbit will send me a new Surge. Was still under warranty. Thank you for the support
02-14-2017 08:21
02-14-2017 08:21
Hi @Paulth! Thanks for the responding, I'm happy to know that you're will be back on track very soon. Too bad that we coudn't fix the issue. Please feel free to come back with any inquiry that you may have in regards of your Surge. We're like a big family and we're always happy to know from you! ![]()
I dont' know if you're familiar with our Discussions board, there is a really good chance for you to like it. In case that you haven't do so, check it out! You might be interested in this topics: Marathon Training or How do you break out of your sedentary lifestyle?
Have a good day! ![]()
