Charge it until it is full. You can check on the watch or the Web site or phone as well
Wendy | CA | Moto G6 Android
Welcome @Keshavdas! Fully charging your tracker usually takes about 2 hours. Thank you for your participation @WendyB.
Best AnswerI just bought my surge n hooked it up n it vibrates but the screen doesn't turn on. Do I have to leave it for a while before I try n turn it on? Thank you
Hi @Grumpz! Please receive a warm welcome to the Fitbit Community! Well, when you connect your Surge the first time, you should be getting the "Fitbit.com/Setup" information, which is basically what you have to do to connect ti, if you're using a computer. If you're not getting that information, please restart your Surge and you should see that information or the battery signal. ![]()
Once your Surge is fully charge you can follow the Setup steps in your phone. Your Surge takes around 3 hours to get a fully charge. Remember to check the syncing requirement in this post first to confirm compatibility. Then follow these steps:
If you're using a Windows 10 computer you will find Setup instructions in this helpful post.
Hope it helps! ![]()
