08-15-2017 21:44
08-15-2017 21:44
My timezone is loaded as the right country but out of the blue my time has changed to completely wrong . It is 4.44pm and it is showing 11.58
08-16-2017 02:31
08-16-2017 02:31
Hi, @hockey3, if your timezone is correct in your app, syncing your Surge should update the clock.
08-16-2017 14:29
08-16-2017 14:29
Unfortunately it has not worked when I synced it
08-16-2017 18:06
08-16-2017 18:06
Actually it will not sinc today - I have turned off the computer and went back in to Fitbit - still no sincing. Sinced yesterday and that did not update the time.
08-16-2017 19:09
08-16-2017 19:09
I'm with same problem since 2 days ago. Do you already resolve this situation?
08-17-2017 03:20
08-17-2017 03:20
Hi, @hockey3, there is currently an issue with Fitbits syncing with Android devices following a recent update. Fitbit is working on this.
In the meantime you may have better luck syncing with your computer using either the Windows 10 app and your computer's built in bluetooth, or the Fitbit Connect software using the sync dongle.
08-17-2017 07:41
08-17-2017 07:41
I'm having the same problem. I haven't worn my fitbit in weeks because it displays the wrong time - fitbit indicated it's 2:41 when it's actually 7:40. And I use IOS with my ipad as my main device for syncing.
08-17-2017 19:08
08-17-2017 19:08
08-17-2017 19:09
08-17-2017 19:09
