02-11-2016
10:48
11:56
02-11-2016
10:48
11:56
For the last couple of weeks I thought that my Surge is not counting steps correctly. Over the weekend I noticed that the number got stock and after about ten minutes it started counting again. I continue to see that my steps are unusually low for the distance that I normally walk. Any thoughts?
Moderator Edit: All-caps
Best Answer02-18-2016 04:42
02-18-2016 04:42
@FitDom I did a live chat with fitbit support and would highly recommend doing this. I had done a step test with my surge and Ultra the results were 1st test Surge 75 me 100. I then did a second test a few hours later results Surge 61, Me 100, Ultra 97. I gave fitbit support these results and that I had reset the tracker 5 times and tried wearing the device in different positions on my arm all with the same result. They are sending me a replacement and I live in Australia. You need to tell them it was a gift, I had my receipt and sent that via Email, as yours was a gift and you don't have the receipt you need to let them know. I would also do the step test so you have some proof that it's defective. Good Luck! I certainly found support very helpful and courteous. Also let them know the screen freezes and won't count.
02-11-2016 11:15
02-11-2016 11:15
My first thought woild be a tracker restart.
Then maybe turning it off through its serting menu.
Then press any button to turn on.
Best Answer02-11-2016 11:17
02-11-2016 11:17
Best Answer02-13-2016 08:05 - edited 02-13-2016 08:08
I wpuld try the 2 button restart of the tracker
Best Answer02-13-2016 17:29
02-13-2016 17:29
Best Answer02-13-2016 21:17
02-13-2016 21:17
02-13-2016 22:38
02-13-2016 22:38
02-13-2016 22:42
02-13-2016 22:42
Best Answer02-13-2016 22:48
02-13-2016 22:48
Best Answer02-13-2016 22:56
02-13-2016 22:56
Best Answer02-13-2016 23:13
02-13-2016 23:13
Are you in the USA? I'm in Australia and extremely disappointed in this.Please let me know how you go with support!
Best Answer02-14-2016 11:57
02-14-2016 11:57
Best Answer02-14-2016 12:51
02-14-2016 12:51
Best Answer02-14-2016 12:53
02-14-2016 12:53
Best Answer02-15-2016 03:37
02-15-2016 03:37
Not sure if this will work but yesterday I changed my sleep setting to sensitive last night my surge was close to 3500 steps behind my ultra. Today I changed the watch so it was facing the inside of my arm and it has tracked much better. Yes it has tracked my wrist movements as steps but that has made up for the steps it missed and tonight it is 300 steps above the ultra ( better than 3500 behind). Will see how it goes tomorrow, hopefully it will track better again! I still have my setting to sensitive and non dominant hand.
Best Answer02-15-2016 04:49
02-15-2016 04:49
Best Answer02-15-2016 05:00
02-15-2016 05:00
Best Answer02-15-2016 05:35
02-15-2016 05:35
It is for how it determines movement while sleeping. In sensatie any movement if the arm will be interpreted as being awake. In normal only the largest movements will be shown as awake, withe the smaller as restless.
yhe dominant setting is used to control how the Fitbit filters out false steps.
My feeling is by moving yhe Fitbit to the other sidebof the arm has tge biggest affect.
Best Answer02-16-2016 04:05
02-16-2016 04:05
So today my surge started tracking well, it was even or above my ultra until I went for an 8 klm walk then lost 1200 steps so not sure what the difference was yesterday compared to today. I reset the surge again yesterday but don't think that would have done it. I did shift the surge at my arm for my walk so tomorrow will leave it and see how that goes. I did do a 2 klm walk at lunch and counted the steps the first one surge 91 me 100 2nd count surge 100 me 100 so the only thing I can think of was the placement. Hoping to get this at least 95% accurate or it goes back!
02-18-2016 04:42
