03-10-2016 23:24
03-10-2016 23:24
09-25-2016 01:08
09-25-2016 01:08
Best Answer09-25-2016 09:26
09-25-2016 09:26
@Ukdoug Welcome to the Fitbit Community! I recommend performing a restart a couple more times. Then, follow the steps on this syncing master post to fix this issue. That should definitely help you out. If you keep experiencing issue after trying that; report the problem to customer support to get further assistance.
Let me know how it goes! ![]()
Best Answer10-06-2016 04:53
10-06-2016 04:53
Hi im using surge since march-16.
So since monday ie 03/10/2016 my samsung grand is not getting synced with the device even after good net conncetivity,Have tried several options like,
Sign in and out
uninstall and install
pairing bluetooth,gets paired but cannot sync.
the sync bar keeps on moving for syncing but cannot gets updated.
Please let me know the proper solution.
Regards
Rohit.
Best Answer10-11-2016 10:55
10-11-2016 10:55
My Surge sync'd fine for 3 months and then overnight battery life dropped from 7 days to 2 and syncing all but disappeared. It syncs randomly every couple of days via wireless dongle, but bluetooth syncing seems completely dead. Because I bought the Surge online and not via an authorised reseller, Fitbit are denying me the warranty cover. That is their right because that is what their small print says, but, when companies like Apple are proud enough of their products to provide care whoever you buy from, it makes Fitbit look a bit Mickey Mouse. Should have bought an Apple Watch. Not much more expensive, but with customer service that is light years better.
Fitbit clearly have an issue with the Surge with battery life and syncing, but are hiding behind the limited warranty to deny proper cover.
Best Answer02-11-2017 12:39
02-11-2017 12:39
Please ignore the stupid name.
I think I may have the answer:
1) Your fitbit device may need a software update which you can from your fit bit app on the phone or laptop.
2) The time and date may be set incorrectly on your smartphone/tab or computerlaptop. Once the date and time are set correctly then it should synch.
Please let me know how you get on?
Best Answer03-03-2017 17:24
03-03-2017 17:24
I need an answer
18:17
07:20
JuanJoFitbit
03-03-2017
18:17
07:20
JuanJoFitbit
Have you tried turning off your Fitbit Surge? I was having issues syncing my Surge and the battery is running down within a day. I figurine it is just like my phone.
I just turned my Surge off then back on. It starting to sync immediately. Best of luck.
Have you tried turning off your Fitbit Surge? I was having issues syncing my Surge and the battery is running down within a day. I figurine it is just like my phone. I just turned my Surge off then back on. It starting to sync immediately. Hope this helps you.
Moderator edit: merged reply
Best Answer04-25-2019 01:09
04-25-2019 01:09
Thanks but doesn't work.
It seems that Fitbit does not support devices long term (more than one year)
Best Answer09-20-2021 12:25
09-20-2021 12:25
I've had the same issues. This thing is a piece of junk. They've offered me a 35% discount on the next Fitbit I purchase...as long as it's not one of their popular items. Needless to say, I won't be purchasing any more of their items. Screw them.
