Hope someone can help.
My surge does not sync. this has happened before, but the problem was resolved.
This time after resetting the tracker and re-installing the fitbit program the syncing still does not work.
Any suggestions will be appreciated.
Trevor
Best AnswerMy surge has also recently stopped syncing. The only way I can get it to work is if I completely shut down the Surge and then turn it back on. It will then sync once, but after that I will have to shut it down again to get it to sync again.
Best AnswerYes, me too having issues with syncing even after resetting. I also had issues with a recent Windows 10 upgrade which through my bluetooth out on the PC...any connection I wonder?
Best AnswerIf i uninstall and re-install fitbit on my cellphone as well as reset the tracker on the surge, then it syncs.
This i have to do every time i want to sync data. I am sure by now fitbit must know there is a problem and hopefully a upgrade will fix it. In hind sight i am sorry i did not go the Garmin route. Unfortunately i did not do enough research before buying the surge.
Best AnswerMy surge isn't syncing either. Mine still thinks it is yesterday & hasn't registered a new day. Tried resetting watch several times. Restarted phone. Now trying to take fit bit off phone & reinstall. Hoping that works. Any other ideas?
Best AnswerMy surge isn't either. Tried everything 😕
Hi guys! Please receive a warm welcome to the Fitbit Family! It's great to see you participating in our Community! ![]()
If you're still having issues syncing your Surge please check the requirements that you phone needs to have to connect properly and check these troubleshooting steps for Android platform and iOS devices too. I'd recommend getting back with the specific error message and model number that you're using to connect.
I'll be around! ![]()
