Allow me to help you @kellen1965! I just tried to connect Fitbit with MyFitnessPal and I was able to do the procedure. However, I noticed that you posted from your iPhone and you may be using your mobile device to link both apps.
I would like you to try connecting both apps using your computer. To do so:
- Go to MyFitnessPal > click on apps
- seach for Fitbit > click on connect > get started
Hope this helps.
Best AnswerHi @KimmiK
Have moved this thread from the Charge HR to the Third Party Integrations section to increase the chance of getting a solution.
Your post will get more attention here.
@Missslater86 A warm welcome to the Community! I've seen various users saying that they are having an issue while trying to link Fitbit with MyFitnessPal. However, I was checking in MFP website to see if there was any bug about it but I couldn't find anything.
I tried to do the procedure and I was able to get it working. Could you confirm that you're doing this linking procedure?
Also, another user mentioned that she just logged out of the Fitbit Dashboard and after that she was linked both accounts.
Hope this helps. Let me know how it goes.
@Missslater86 @Pattiy888 A warm welcome to the Community! Thank you for the details that you've mentioned. MyFitnessPal mentioned that they were having issues. In case you're still not getting the correct data from MFP you can try unlink and relink both accounts to see if it starts working.
To do so: Go to your MFP account > click on apps > find Fitbit > disconnect.
Best AnswerI had the same problem. Right past authentification it kept sending me to fitbit.com/oauth. If any of you guys run into the problem when trying to connect MFP with Fitbit through your mobile devices, try doing it from the MFP website using a computer. It worked for me right away, but for the changes to take effect, you'll also have to log out of Fitbit on your phones and then log back in.
