@Chris-m It's great to see that you've visited the Fitbit Community!
I would recommend to revoke the access of the Weight Watchers App and then link them again.
Hope this helps. 🙂
It is health that is real wealth and not pieces of silver and gold! Share your story!
Hope this helps. 🙂
01-04-2016
07:36
10:40
01-04-2016
07:36
10:40
@freesia29 Welcome to the Fitbit Family! 🙂 Did you try the procedure on this help article: Can I connect my Fitbit and Weight Watchers accounts? , keep me posted about the resolution from WW support team!
Catch you later! ![]()
Moderator Edit: Fixed link
Best AnswerMine aren't either. When I got to the Fitbit app and select the WW app, it states that my device doesn't support the WW app, even though I already have it. Spent over an hour with WW support and nothing works.
Same with me, I did not get an answer.......
Hello @TheRobV, hope you are having a great day! Activities tracked by Fitbit will be converted to activity "PointsPlus" and credited to your Weight Watcher's account. Food information is not transferred from Fitbit to the WW account. @tazstweet @dmdresp and @LisaLisa16 did you try revoking access and then link both accounts again?
Best AnswerAngela - the problem is that weight watchers updated their app and website. I've tried multiple times to revoke access, cancel the link and re-link it. it's STILL not working. I tried resetting my fitbit charge HR and now the time is off by 4 hours! My fitbit is totally messed up now. I can't even use it.
I recently went from zip to Hr Charge, I am connected to the weight watchers app however its not synching. I did try to revoke access, however weight watchers is not showing up in my applications for some reason.
Ive contacted weight watchers support, they are ZERO help.
I am now having the same problem with my replacment charge that I had to get on Sunday because the one I got for Christmas was defective, I have taken the above steps several times and still no results. I have tried to manually make it sync via their link, nothing. I give up!
I revoked rights and can not get Fitbit linked with WW. Please help
