11-30-2015 11:50 - last edited on 12-01-2015 08:05 by AngelaMa
Has stopped syncing with weight watchers tracker.
01-06-2016 19:10
01-06-2016 19:10
01-06-2016 19:45
01-06-2016 19:45
I disconnect from WW and when I connect WW doesnt ask for Fitbit credentials.
01-06-2016 20:08
01-06-2016 20:08
01-06-2016 21:17
01-06-2016 21:17
Mine isn't syncing either-and I've revoked access and tried again. I think the problem is with WW and not fitbit.
01-06-2016 23:25
01-06-2016 23:25
It's definitely a Weight Watchers problem, I'm interested to see if mine will work today but I'm doubting it. It all seems very random!
01-07-2016 09:46
01-07-2016 09:46
I'm having the same issue. I have called WW three times now and have been told to "be patient". This is very frustrating. The old directions posted on FitBit's site do not work with the new update at all.
It appears to be synced but it is not working at all. I have tried everything. Connecting, disconnecting via WW and Fitbit. Forcing sync, all-day sync, etc. They have "escalated" my problem at WW, but this is very frustrating.
01-07-2016 11:02
01-07-2016 11:02
Hello @dmdresp @A_2E, @DesWo and @JeannetteP welcome to the Fitbit Community! It's great to have you here 🙂 @Jen_F not syncing with WW shouldn't affect your tracker's functionality, please contact Fitbit customer support so they can review your tracker's software. Keep me posted! @LisaLisa16 it's great to know your accounts are syncing properly. 🙂 @Jenny51 thanks for the update, hope they find a solution soon! @JeannetteP @SunsetRunner have you tried the procedure on this help article? if you already did please contact WW directly so they can further assist you.
Thanks for stopping by, see you around!
It is health that is real wealth and not pieces of silver and gold! Share your story!
01-07-2016 12:08
01-07-2016 12:08
01-07-2016 18:00
01-07-2016 18:00
01-07-2016 18:56
01-07-2016 18:56
01-08-2016 05:44
01-08-2016 05:44
Hello @A_2E and @Tinkr57, welcome to the Fitbit Community! It's great to have you here 🙂 @Tinkr57 Are you getting an error message when trying to connect Fitbit with your WW account? Have you followed the steps on this help article: Can I connect my Fitbit and Weight Watchers accounts? @A_2E if you already tried the steps above I would recommend to contact WW support so they can follow up on your case.
Keep me posted! 🙂
01-08-2016 06:09
01-08-2016 06:09
01-08-2016 13:11
01-08-2016 13:11
01-08-2016 17:44
01-08-2016 17:44
01-08-2016 18:49
01-08-2016 18:49
I have disconnected and reconnected on my laptop numerous times. I have previously revoked WW access from Fitbit and now I can't get Fitbit to see WW>>>>>>>>
01-08-2016 18:50
01-08-2016 18:50
01-09-2016 07:19
01-09-2016 07:19
Hello @Bacon4Bacon, welcome to the Fitbit Community! It's great to have you here. Thanks for your amazing cooperation, hope to see you around more often 🙂 @Tinkr57 I would recommend to contact customer support, let them know with details the issue you are experiencing and the steps you did to solve it, if possible include a screenshot of the WW page where it shows it is connected to Fitbit so they can further investigate. @JeannetteP is Fitbit showing on the WW app as linked?
Keep me posted.
01-10-2016 05:59
01-10-2016 05:59
If you do the change from the full Weight Watcher site, see if when you log back in to FitBit, it shows that Weight Watchers is allowed again. It could take several hours or a day for this to appear. Once you see Weight Watchers is allowed again by FitBit, it took 24 hrs for the data to start being sent again to Weight Watchers. Nothing was instantaneous. So first try to reestablish the connection with FitBit. I could only do this through the full Weight Watcher.com site, where it goes through the prompts of signing in to FitBit.
It also looks like FitBit had been addressing integration problems with other devices, so maybe it is all one in the same, not sure.
01-10-2016 06:03 - edited 01-10-2016 06:04
It took almost a day for FitBit to show it allowed Weight Watchers again, and then almost another day once recognized for the data to start to transfer. I guess I expected it to be instantaneous, but it definitely wasn't. Once the connection is reestablished with FitBIt, I it does eventually start to send to Weight Watchers, but not in real time. Could be hours,or a day later from what I have seen.
01-10-2016 20:49
01-10-2016 20:49
