11-30-2015
11:50
08:05
AngelaMa
11-30-2015
11:50
08:05
AngelaMa
Has stopped syncing with weight watchers tracker.
Best Answer12-01-2015 08:05
12-01-2015 08:05
@Chris-m It's great to see that you've visited the Fitbit Community!
I would recommend to revoke the access of the Weight Watchers App and then link them again.
Hope this helps. 🙂
It is health that is real wealth and not pieces of silver and gold! Share your story!
01-08-2016 17:44
01-08-2016 17:44
11-30-2015 11:54 - edited 11-30-2015 11:56
Hi @Chris-m
Moved your post to the Third-Party Integrations section since being more relevant to the topic and increase the chance of getting a solution.
Wishing a wonderful day
12-01-2015 08:05
Hope this helps. 🙂
12-01-2015 08:58
12-01-2015 08:58
01-03-2016 11:24
01-03-2016 11:24
This is not working for me. When I add Fitbit to the WW devices, I am not getting a login screen to connect the 2 apps. On with WW tech support now too.
01-04-2016
07:36
10:40
01-04-2016
07:36
10:40
@freesia29 Welcome to the Fitbit Family! 🙂 Did you try the procedure on this help article: Can I connect my Fitbit and Weight Watchers accounts? , keep me posted about the resolution from WW support team!
Catch you later! ![]()
Moderator Edit: Fixed link
Best Answer01-04-2016 10:40
01-04-2016 10:40
I've connected my WW app and my FitBit, but my steps data and food tracking info aren't moving over.
01-04-2016 16:07
01-04-2016 16:07
Mine are not moving over either and they are linked but i dont know why they arnt going to my ww account
01-04-2016 17:15
01-04-2016 17:15
Mine aren't either. When I got to the Fitbit app and select the WW app, it states that my device doesn't support the WW app, even though I already have it. Spent over an hour with WW support and nothing works.
01-04-2016 17:31
01-04-2016 17:31
Same with me, I did not get an answer.......
01-05-2016 07:08
01-05-2016 07:08
Hello @TheRobV, hope you are having a great day! Activities tracked by Fitbit will be converted to activity "PointsPlus" and credited to your Weight Watcher's account. Food information is not transferred from Fitbit to the WW account. @tazstweet @dmdresp and @LisaLisa16 did you try revoking access and then link both accounts again?
Best Answer01-05-2016 09:30
01-05-2016 09:30
Angela - the problem is that weight watchers updated their app and website. I've tried multiple times to revoke access, cancel the link and re-link it. it's STILL not working. I tried resetting my fitbit charge HR and now the time is off by 4 hours! My fitbit is totally messed up now. I can't even use it.
01-05-2016 10:06
01-05-2016 10:06
01-05-2016 12:47 - edited 01-05-2016 12:48
I recently went from zip to Hr Charge, I am connected to the weight watchers app however its not synching. I did try to revoke access, however weight watchers is not showing up in my applications for some reason.
Ive contacted weight watchers support, they are ZERO help.
01-05-2016 15:11
01-05-2016 16:48
01-05-2016 16:48
01-05-2016 19:40
01-05-2016 19:40
I am now having the same problem with my replacment charge that I had to get on Sunday because the one I got for Christmas was defective, I have taken the above steps several times and still no results. I have tried to manually make it sync via their link, nothing. I give up!
01-06-2016 13:30
01-06-2016 13:30
I spoke to someone at WW at the fitbit / WW app syncing problem tonight and they said they are aware of it and it's being looked at.
01-06-2016 15:46
01-06-2016 15:46
01-06-2016 18:11
01-06-2016 18:11
I revoked rights and can not get Fitbit linked with WW. Please help
