01-03-2018 14:07 - last edited on 06-09-2018 04:48 by RobertoME
I would like to sync my weight/bmi/fat% to my fitbit account/dashboard. Maybe the other way around also the steps from fitbit into the nokia health mate app.
anyone any idea where to start? All the links in other topics and the help pages lead to 404 pages, for example: https://help.fitbit.com/articles/en_US/Help_article/1286/?l=en_US&c=Topics%3AX3rd_Party_Integration&...
any help is greatly appreciated!
cheers,
tom
Moderator Edit: Updated Subject For Clarity.
02-03-2019 03:59
02-03-2019 03:59
Anch'io sono Italiano... Allora dimmi una cosa... Ma funziona la connessione con la mia FitBit Alta Hr? Ho la Nokia/Withings bilancia e non mi registra il peso... La tua APP lo farebbe?
Fammi sapere e la compro subito.
Grazie
02-03-2019 04:39 - edited 02-03-2019 06:30
Ciao @Puroplatino,
grazie per l'interesse. WeightHub si collega senza problemi a Withings e Fitbit.
Il braccialetto Fitbit Alta HR trasmette i dati a Fitbit tramite l'app bluetooth.
La bilancia Nokia/Withings trasmette i dati via WiFi a Withings.
Usando manualmente l'app WeightHub, puoi sincronizzare i dati di peso e massa grassa da Withings a Fitbit.
Nota: WeightHub funziona solo su desktop Windows 10 o macOS.
Fitbit Alta HR -> Bluetooth -> Fitbit app -> Internet -> Fitbit cloud.
Bilancia Nokia/Withings -> WiFi -> Withings cloud.
Withings cloud -> Internet -> WeightHub -> Internet -> Fitbit cloud.
Buona giornata!
02-03-2019 09:19
02-03-2019 09:19
02-03-2019 09:34
02-03-2019 09:34
As a former Withings user and a new FitBit user, please correct me if I am wrong in my understanding of this scenario. It seems to me that most (but not all) of the criticism seems to be directed at FitBit (perhaps because we are on a FitBit Forum) but the integration of devices from two different manufacturers is actually not done by FitBit, but by Withings. If the problem is with a Withings app, why is the criticism not directed at Withings? Withings may well have decided to not assist the customers of their rival. I spent many years with Withings because of their better dashboard and continued with them because of my investment in their product. After numerous product failures and data inaccuracies, I started to look around and actually synched my Withings scale with a FitBit account. I stayed with Withings because of the data displays but that went in the toilet when Nokia took over. Now that I have switched to FitBit, I cannot switch the Withings scale data for my wife to her dashboard because of this failure but my data comes over fine since I did the synch two years ago.
02-03-2019 09:57
02-03-2019 09:57
Keith, I direct the blame primarily at Fitbit for a few reasons.
1) Fitbit's history of poor support and syncing. Maybe this could be a lesson that constantly squandering their customer's goodwill doesn't serve Fitbit in the long run.
2) Withings actually has a BANNER on their website saying they are aware of the syncing issue and trying to work it out with the Fitbit API team. Meaning I don't have to go to a forum for acknowledgement of the issue. They've even had a rep post HERE about the issue. Fitbit simply comments that they have no new information or ETA for a fix.
3) It is in Withings best interest for this integration to work, what with Fitbit being the market leader and this issue affecting every one of Withings products. Fitbit on the other hand can be content to tell people to get an Aria.
4) There was recently an issue with Withings and IFTTT syncing. Got fixed in less than 2 days by Withings. This issue has been lingering for months.
5) Just because the plugin is developed by Withings does not mean that Fitbit couldn't have changed something on their end that essentially makes fixing the plugin impossible or severely limits its functionality.
02-03-2019 11:45
02-03-2019 11:45
Thanks for sharing your insights.
02-03-2019 12:40
02-03-2019 12:40
02-03-2019 15:28
02-03-2019 15:28
Hello,
My Health Mate app won't sync to my Fitbit like it used to.
I tried to reconnect them, but when I log in and I choose the account I want to sync from, I get
this message...
Can anyone help me?
Thanks,
Margootemans
02-03-2019 16:40
02-03-2019 16:40
Since your trying to log into your Nokia account, and the error is a from the Nokia server I suggest contacting them.
02-03-2019 23:50
02-03-2019 23:50
This is what Whithings said.
Thanks 😉
02-04-2019 10:10 - edited 02-04-2019 10:12
Withings posted an updated today in their support forum: Update Feb 4, 2019
02-04-2019 10:55
02-04-2019 11:17
02-04-2019 11:17
@lmgray wrote:Withings posted an updated today in their support forum: Update Feb 4, 2019
Well, at least now its clear the delay is on Fitbits end. And now we wait (some more).
02-04-2019 11:54 - edited 02-04-2019 11:55
Maybe this week-end I will develop an alternative Withings to Fitbit web integration, to transfer weight and fat in real-time or similar.
02-04-2019 12:08
02-04-2019 12:08
02-04-2019 14:11
02-04-2019 14:11
Since you have contacted them, hopefully they will let you know when the issue is fixed
02-05-2019 06:30
02-05-2019 06:30
The response from Withings side is that Fitbit are using an outdated version of Withings/Nokia's API hence the connection issues
02-05-2019 08:34
02-05-2019 08:34
Please let us know what Fitbit has fixed this.
02-05-2019 09:07 - edited 02-05-2019 09:08
The Fitbit / Withings scale issues appear to be resolved for me, I am a previously authenticated user so I don't know if new users trying to setup sync for the first time will have the same result. When I go to https://www.fitbit.com/weight/withings I can see that my weight is again syncing, it had been broken since 1/28/19 (after nearly 7 years of flawless syncing).
Thank you to the development and support teams that have worked to resolve this issue! It is greatly appreciated.
02-05-2019 09:13
02-05-2019 09:13
Unfortunately, didn't work for me (though got one stage further in the process compared to last time).
