Update 2/25/16 3:00pm
Update from MFP, looks like things are starting to return to normal!
"Although we have recently experienced delays with the sync between Fitbit and MyFitnessPal, things should be moving once again. While there may be some residual traffic, things should be getting back to normal shortly.
We will continue to monitor the situation and update this article if we see the issue resurface. Thanks for your patience"
Thanks to everyone that reported the issue. ![]()
Update 2/25/16 10:22am
Hey guys, a syncing issue with MFP was reported this morning. ![]()
MFP is aware of the problem and they're working on it. You can find their updates here.
"Members are experiencing delays with information transferring to and from their MyFitnessPal and Fitbit accounts. The team is working on the issue and we hope to have this resolved as soon as possible. Please do not reconnect your accounts at this time, as this may cause longer delays in the sync.
We will continue to update this article as more information becomes available. Please check back for further updates."
I'll continue to update this thread. Hang tight!
Everyone -- I've merged several of you from the Android board into this floated thread in our Third-Party Integrations board. I recommend checking out @AndrewFitbit's lead-in post here for updates.
Best AnswerMy food diary stopped syncing with fitbit after breakfast today. It will not sync any snack or lunch. Hesitant to unsync or disconnect apps as I'm not sure how to do it. Rather disappointing when my dashboard shows I'm terribly low on caloric intake for the day.
Best AnswerNow I am having the same issues. Everything is working except the syncing of the food logged on MFP. It has been working beautifully until today. Ran through all the troubleshooting repeatedly. No dice...
Any other recommendations?
Chris
