Update 2/25/16 3:00pm
Update from MFP, looks like things are starting to return to normal!
"Although we have recently experienced delays with the sync between Fitbit and MyFitnessPal, things should be moving once again. While there may be some residual traffic, things should be getting back to normal shortly.
We will continue to monitor the situation and update this article if we see the issue resurface. Thanks for your patience"
Thanks to everyone that reported the issue. ![]()
Update 2/25/16 10:22am
Hey guys, a syncing issue with MFP was reported this morning. ![]()
MFP is aware of the problem and they're working on it. You can find their updates here.
"Members are experiencing delays with information transferring to and from their MyFitnessPal and Fitbit accounts. The team is working on the issue and we hope to have this resolved as soon as possible. Please do not reconnect your accounts at this time, as this may cause longer delays in the sync.
We will continue to update this article as more information becomes available. Please check back for further updates."
I'll continue to update this thread. Hang tight!
Best AnswerI have noticed that my Aria scale is not syncing with my MFP account. MFP doesn't have my current weight. I had to add it manually this morning. I have revoked access, uninstalled MFP, reinstalled MFP, to no avail. This is very frustrating!
Best AnswerSame here. MFP has 20 steps logged, which would have been right after midnight, but nothing is synching. Guess I'll just wait and see.
Best AnswerNot syncing for me since yesterday
Best AnswerHi all
I just saw this over on MFP....
Fitbit Sync Issues 2/25/16
Thought as much. And of course the problem is on the MFP end. If it weren't for how well it handles recipes I'd probably ditch it entirely.
Best AnswerI did this and it just made it ten times worse. Now they are not lynced at all even though it says they are.
Actually, now myfitnesspal deleted all of my data for the last 8 years. So it made it ten thousands times worse. Don't do this if your apps aren't lycned together. It will just make it worse.
