I can think of a few reasons, but they would only be guessing.
The Fitbit developers have their hands full, with the new products.
S-Health might not have a desire to hook up to Fitbit.
Not enough interest shown on the feature request, link found above.
one of the users made an app to do this called fit and healthy
Fitbit has the API setup so it's easy for third parties to attach to your account.
Best AnswerWhy is this marked solved? Another similar thread was marked the same way. Telling people "submit a suggestion, I hope it will be added too!" Is NOT a solution, its a suggestion. I have a feeling one of the reasons the devs have NOT solved it is that someone keeps marking these threads as solved when they are NOT.
UPDATE 7/29/2016:
Still NOT solved that I can tell, but if you are willing to use S Health instead of Fitbit app you CAN import your data to it via an app by jsonlo called Fit and Healthy.
Let's look at this, currently there is no direct connection between Fitbit and S-Health. Since it was the person that asked the question who marked the post as solved, my fires is that they realize that for anything to change, Fitbit developers will need to notice that this feature is wanted. Since it is the feature request is where the developers monitor, the best answer will be to vote. The second best answer would be to look at the other thread which does mention an app that a Fitbit user wrote that does connect your data between S-Health and Fitbit. Fitbit has their hands currently full, generally does not initiate a connection to 3rd party apps. However they have an open API, which allows and 3rd party to rapidly connect to your data. If S-Health really wanted they could make their own connection tomorrow.
I already installed that app and it only does weight. If there is a real solution I would really like to know since I haven't found it yet. Its great that jsonlo is actually doing something about it, and I told him so. But it is not yet solved that I can tell.
UPDATE 7/29/2016:
Thanks for the advice. Since S Health allows you to import most of your Fitbit data now, I moved to S Health. While I was at it, the new Gear Fit2 was so pretty and went with my Samsung Note5 so well, I bought it and ditched my Charge HR. Now I just import my weight data from my Aria and don't worry about the rest. I'm sure abandoning Fitibit products and platform is exactly the result Fitbit was looking for!
For the most part a thread wool say solved when the programs poster finds a post that has been helpful to them. Apparently they felt the past pointing to the Thad whee it is possible to vote on this request is helpful.
This is not a soltion, it is a work around and it does not sync all info. Nice try but not good enough to make the sale. I will just continue to use S-Health until Fitbit figures out that they are the ones that need to do this!
