05-25-2017 06:47
05-25-2017 06:47
I use Strava to sync my rides into Fitbit. Has worked seemlessly until a couple days ago. It started as a huge delay (hours). Last night took some time. Now this morning's ride hasn't synced (it's been almost 3 hours). Curious if anyone else has been having this issue.
Best Answer05-25-2017 13:28 - edited 05-25-2017 15:14
Hey all, thanks for reporting this. We'll investigate and see what's going on. ![]()
Edit: This should be resolved now. Thanks again for the reports!
05-25-2017 07:01
05-25-2017 07:01
Same issue here. I sync with Strava on every ride; today, no sync. My buddy uploaded to Strava directly just fine on same ride, so seems to be an integration issue.
Best Answer05-25-2017 07:18
05-25-2017 07:18
To be clear, I use Strava just for the ride (mostly because it has the ability, if I so choose, to share to social media). I have Strava import into Fitbit, and let Fitbit work its magic/use it for the fitness/physical/biometric data.
Best Answer05-25-2017 09:12
05-25-2017 09:12
For kicks, I decided to try a fix from when it wasn't working about a year ago this time. I am now thinking I should not have done that. I did the "revoke and reconnect thing".
This error came up: {"statusCode":500,"error":"Internal Server Error","message":"An internal server error occurred"}. However, Fitbit and Strava, both on their respective sites, show them as reconnected and with permissions for write and access.
Best Answer05-25-2017 09:27
05-25-2017 09:27
Same issue here!
I think it's some sort of server issue, hopefully it will get fixed quickly.
Best Answer05-25-2017 09:28
05-25-2017 09:28
I got the exact same issue. Must be an IT issue behind the scenes.
Best Answer05-25-2017 11:59
05-25-2017 11:59
Yup.. My run this evening didn't sync to strava either..
Becoming an annoying habit.. Same issue a few weeks back and took long enough to fix
Best Answer05-25-2017 12:54
05-25-2017 12:54
Me too, same exact error.
Tried on two pc's and on two separate internet connections.
Best Answer05-25-2017 13:10
05-25-2017 13:10
Getting the same thing feom my ride today.
I tried the revoke access and reconnect but get the error 500 when clicking connect on strava.fitbit.com
I got round it by downloading the fitbit activity as a .tcx file and then manually uploading it to Strava.
05-25-2017 18:07
05-25-2017 18:07
I was able to reconnect Strava and Fitbit. Will my two rides from today that didn't sync originally because of this issue now sync since it appears to be resolved?
Best Answer05-26-2017 00:00
05-26-2017 00:00
I'm guessing they won't.
But you can export your activity from fitbit then manually import it into strava. Like Nairnster has.
05-26-2017 00:08
05-26-2017 00:08
Seems to be working again properly. I deleted the activity from Strava, and then after a while the fitbit activity did sync across to Strava.
Best Answer05-26-2017 02:36
05-26-2017 02:36
No, I meant FROM Strava TO Fitbit.
Regardless, I figured that would be a stretch.
We'll see this morning if it's truly fixed.
Best Answer05-28-2017 03:57
05-28-2017 03:57
Still not syncing from Fitbit to Strava!
few days ago I downloaded the file uploaded to strava manually... but as next week I'll be on a trip for 10 days I won't have my computer with me! You better solve this asap!
Best Answer05-28-2017 04:17
05-28-2017 04:17
Best Answer05-28-2017 04:34
05-28-2017 04:34
I revoked access again and again connected. After 30min it synced my last training from this morning. Ok, it seems to work now.
Best Answer05-30-2017 06:47
05-30-2017 06:47
Doesn't wok for me still. See screenshots from FitBit and Strava.FitBit
Strava
Best Answer06-06-2017 04:34
06-06-2017 04:34
This isn't solved. It appears to be broken again.
06-06-2017 06:57
06-06-2017 06:57
I don't use fitbit, but my company has this fitbit challenge thingy. I am using Garmin and sync to Strava all my runs and rides. I thought I can sync Strava to fitbit and participate in the challenge, but no luck.
