02-16-2016 03:41 - edited 02-16-2016 03:43
Hi!
I'm searching for a scale and was wonderng whih scales are compatible with Fitbit.
I know, that Fitbit Aria and Wihtings can be connected directly with Fitbit. Are there more scales that can be connected directly?
And is it possible to connect a scale indirectly with Fitbit? By walk-around if you wanna say so? For example through another app (f.ex. Runtastic Libra with MyFitnessPal with Fitbit)
Thank you for your help.
Plunse
03-10-2022 16:38
03-10-2022 16:38
Hello everybody, thank you for visiting the Fitbit Community.
Officially, Fitbit Aria Scales and Withings Scales can sync directly with Fitbit. However, there are some other scales that might sync with Fitbit too. Our team is constantly working to improve our products and services. Your feedback is highly appreciated.
If you would like to make any suggestion, you are welcome to visit the Feature Suggestions board which is constantly monitored by our engineering team for future implementations.
I am going to close this thread because it is too old, but if there is anything else we can help you with, please don't hesitate to start a new topic.
Have a nice day.
Best Answer02-16-2016 08:06
02-16-2016 08:06
Those are the only two I am aware of and only a Fitbit product can be directly connected to your Fitbit account.
02-16-2016 10:34
02-16-2016 10:34
Welcome to the forums @Plunse! As you've mentioned, the only 2 scales that connect to Fitbit are Fitbit Aria and Wihtings Wireless scale.
You can check in the MFP Apps page for scales that link to MFP, but you'll need to check within the individual products if the weigh logs through that scale are transmitted to Fitbit.
Let me know if you have any questions, happy stepping! ![]()
12-07-2016 02:06
12-07-2016 02:06
Do you know which scale from Wihtings that can be used to connect to Fitbit.
Can the Fitbit Aria connect to other places other than Fitbit?
Best Answer12-08-2016 12:19 - edited 12-08-2016 12:25
The scales only connect through their respective accounts. When we say different products connect, we are refferring to your different accoints gor these products.
yhis means any Withings scsle, through uour withings account will sync to your Fitbit account.
As for other companies that can see your Fitbit weight, im not awarebof the actual names right now. Some of the health sites do, like insurance companies.
There ate two apps that im aware of, they both do about the same thing.which is track your daily changes in weight, then displays the direction the weight change of heading, ignoring the normal daily fluctuations. The one app is called Trendweight
08-02-2017 05:48
08-02-2017 05:48
Why do the Fitbit scale don't measure muscle.
08-02-2017 10:45
08-02-2017 10:45
My guess would be that the scale doesnt have the logic to read the body muscle.
08-07-2017 21:09
08-07-2017 21:09
Using IFTT you can sync Wii U Fit scale weight to FitBit
08-14-2017 11:24
08-14-2017 11:24
Now that Nokia has purchased Whitings, is the Nokia supported app compatible with the Fitbit app?
@HelenaFitbit wrote:Welcome to the forums @Plunse! As you've mentioned, the only 2 scales that connect to Fitbit are Fitbit Aria and Wihtings Wireless scale.
Best Answer08-15-2017 11:46
08-15-2017 11:46
I have a new Nokia Body + scale. I see that Aria and Withings(Now Nokia) are the only 2 that sync with the Fitbit app.... BUT.. How exactly do I link the two accounts so I get the Scale info imported to the Fitbit app??
08-17-2017 06:33
08-17-2017 06:33
Go to www.fitbit.com/apps and follow tye prompts.
08-19-2017 10:20
08-19-2017 10:20
Didn't see anything about Withings or Nokia on that App list. So does that mean that Withings is no longer compatible with Fitbit?
Best Answer08-20-2017 14:58
08-20-2017 14:58
I bought a Weight Gurus wifi scale and it integrates with Fitbit.
08-20-2017 14:59
08-20-2017 14:59
Nokia bought Withings so they are one and the same (unless you purchase a Withings that may still be in the market).
Best Answer09-29-2017 04:12
09-29-2017 04:12
This thread was started a while back. Are there any other scales that work now?
Thx.
09-29-2017 05:12
09-29-2017 05:12
I just saw on Fitbit's website that they are now offering the Aria 2. I've moved on from their scale(s) so I have no opinion on its effectiveness or quality.
Best Answer10-01-2017 14:06
10-01-2017 14:06
I'm in the UK and I bought one of these scales by Multifun from Amazon, You need to download an app called Yolanda to get it to work but from there you can sync it to your Fitbit app and it will automatically put the weight in everytime you use it as long as your phone with their app on is nearby.
10-12-2017 05:17
10-12-2017 05:17
I did purchase the WiThings (Nokia) Body Cardio and it works like a charm With Fitbit 🙂
10-18-2017 01:53
10-18-2017 01:53
Does the withings scale send over body fat % to fitbit?
Best Answer10-18-2017 02:47
10-18-2017 02:47
Yes the scale sends body fat% over to Fitbit
