02-08-2022
06:50
07:49
YojanaFitbit
02-08-2022
06:50
07:49
YojanaFitbit
Unfortunately, all related topics are locked, so I'm starting a new topic:
FitBit is no longer receiving data from Withings. The Withings app no longer lists FitBit as a linked app, FitBit does now show Withings as connected.
When attempting to run the connection wizard, I get this error message:
I've tried on multiple devices and nothing works -- it looks like the same communication error between FitBit and Withings that has apparently occurred multiple times in the past.
Is this a known issue at the moment?
02-11-2022 09:33
02-11-2022 09:33
I am back to where we started: FitBit is no longer linked to Withings. Weight data has to be entered manually. If you could push a fix for new users, why is it not possible to push a permanent fix for all users? Especially those of us who have been long time FitBit customers and are paying for a new FitBit Sense and FitBit Pro?
02-11-2022 09:40
02-11-2022 09:40
For me, the wizard worked but that was that 😀 the measurements are not being synced, just one time for the historical data.
I am not sure how hard is it to fix and expired token without introducing bugs to the sync logic.
02-15-2022 00:55
02-15-2022 00:55
Same for me: since severall days no synchronisation - member since 2018 - I really don´t understand why you don´t check the SW-update before launching.....
02-15-2022 00:57
02-15-2022 00:57
Has anybody found a solution for this? I have the same problem since I got the Charge 5. Before it worked without any problems ....
02-15-2022 12:03
02-15-2022 12:03
02-15-2022 12:31 - edited 02-15-2022 12:40
Hi everybody,
Thanks for reaching out the Forums. We really appreciate your comments and feedback about this issue.
Please try to revoke the access from Withings, and reconnect both apps. You can find the steps here: How do I connect my Fitbit account with another app?
I've marked this post as the best answer for this thread to gain visibility. Thanks a million for your cooperation and understanding while we keep working on solving this for all of you. Thank you @TaraDactyl83, your comment was of great help.
Hope this helps. Looking forward to your new comments.
02-15-2022 12:40
02-15-2022 12:40
I was able to update all my weights with this. Hopefully it will keep working going forward. Thanks for fixing this. Would be nice if it didn't happen yearly! 🤣
02-16-2022 08:14
02-16-2022 08:14
Thanks, this did solve the problem!!
02-21-2022 17:31
02-21-2022 17:31
This does not work! Fitbit.com/weight/withings does NOT have an option to “Start the Withings Connection Wizard.” I can not even search for Withings Connection Wizard. It does not exist.
02-22-2022 11:30
02-22-2022 11:30
I followed this https://help.fitbit.com/articles/en_US/Help_article/1742.htm
then selected how to connect Fitbit with another app (it was the first of 3 options) once it loads the withings option is at the bottom. That took me to the wizard and I was able to sync all past stored weigh-ins. Hope you can resolve it. I understand the frustration, as we all chose to get a scale like this to no longer have to manually enter that data.
07-08-2022 08:39
07-08-2022 08:39
Fitbit Integration with my new Withings Body+ scale, using Wizard at:
https://www.fitbit.com/weight/withings
worked great just now to import into Fitbit all weight and %body fat measurements made with the scale.
Thanks!
12-01-2022 10:45
12-01-2022 10:45
Hi everyone!
Thanks for the details provided and your efforts while working on this matter. I'm sorry for this inconvenience and if you haven't done so, please make sure the Fitbit app is updated and check this help article for instructions on how to connect your Fitbit account to another app.
To keep our forums organized, I'm going to close this thread from further comments. However, if you have a different question, you can start a new thread to receive help from the Community. Your feedback is appreciated and we'll keep working to improve our devices, features and overall Fitbit experience.
