06-17-2018
06:27
05:01
MarcoGFitbit
06-17-2018
06:27
05:01
MarcoGFitbit
Fitbit what happening with your syncing !
I have to restart my phone , restart my watch and in the end it doesn't work .
Anyone planning to purchase the watch pls don't they have syncing issues .
The watch is good but the connection for Bluetooth and notification sucks big time.
06-18-2018 05:02
06-18-2018 05:02
Hello @Husain187, thanks for joining the Fitbit Community, it's great to have you on board.
Thanks for bringing this to my attention and for letting me know the troubleshooting steps you've tried so far. Since you have already restarted your phone and your Versa, I would like to suggest you to check the following:
If your device still won't sync, try these steps:
I hope this can be helpful, give it a try and keep me posted in case you need anything else.
06-18-2018 05:02
06-18-2018 05:02
06-19-2018 07:15
06-19-2018 07:15
Hi
It worked to sync my device unfortunately the next day I need to delete the app, restart the watch and do all the process again .
It's really bad .
Everyday the same process delete and reinstall just to sync basically one sync per day .
Time to sell this crap
06-21-2018 17:26
06-21-2018 17:26
Selling a faulty device? That's not cool.
06-21-2018 17:33 - last edited on 09-27-2019 12:18 by LiliyaFitbit
It's not from the device , they advertise that it works on both IOS and
ANDROID just found out that its not compatible with Huawei mobiles .
It worked fine with my iPhone .
I guess I need to change my mobile
Disappointed !
best regards
06-21-2018 17:39
06-21-2018 17:39
06-21-2018 18:03 - last edited on 09-27-2019 12:18 by LiliyaFitbit
It's syncing easily with my spare phone ( iPhone 6 plus ) I'm sure it was
not tested with Huawei devices as I have read alot of posts regarding this
issue especially the Fitbit incharge 2 watch with Huawei.
best regards
10-04-2018 22:41
10-04-2018 22:41
None of this steps work on my Samsung s9. Tried all, only just got the device yesterday. Very unhappy. Works fine last night.
10-07-2018 10:06 - edited 10-07-2018 10:09
I have had my Versa for a few months and never had a problem syncing it on my iPad till last Friday, when suddenly it refused to connect and sync. I tried the procedure suggested by MarcoGFitbit but it still will not sync!
i had a surge before and had to turn that off and restart every time I wanted to synce that but it has always been straightforward with the versa till now.
any constructive suggestions appreciated 🙂
10-17-2018 06:51
10-17-2018 06:51
I have a Galaxy S9+ and syncing has stopped working as well. I'm very frustrated at this point, as none of the steps work. It simply will not connect to bluetooth on the version of Android on my AT&T phone.
10-17-2018 12:32
10-17-2018 12:32
Now that Apple have updated their operating system my versa syncs again! Apparently there was a Bluetooth problem with the previous IOS version. If you have a tablet roguelife you could try syncing with that instead?
10-18-2018 00:06 - edited 10-18-2018 00:07
It's possible but super inconvenient as I do not carry my iPad with me everywhere. I've lost the ability to get notifications. What's ridiculous is that the battery level is still known to the app, but syncing, notifications, and bluetooth do not work right now. 😕
10-18-2018 14:21
10-18-2018 14:21
At least it would show if the problem is with Versa or your phone system if you tried syncing with the tablet 😉
10-18-2018 14:32
10-18-2018 14:32
I have reported the same problem. I have tried the steps below and it does not work.
I am now reading that my Huawei P10 may not be compatible. This was not mentioned anywhere when I purchased the Versa. And it was working perfectly then just stopped.
10-18-2018 14:43
10-18-2018 14:43
The last time I was able to get my Versa to sync with the app was Oct 13. It is October 18. I have turned off, on the Bluetooth, the phone and the versa, I have unlinked/disabled every other Bluetooth device in my house, force stopped the app, and uninstalled and reinstalled the app, still won't sync. Please fix this.
11-20-2018 02:38
11-20-2018 02:38
How is restarting my phone every time I need to sync a solution!? This weekend I spent 20mins trying to get my watch to connect to my phone before I could go for a run. 5 minutes in it disconnected so I don't have a record of my route...
11-21-2018 07:00 - edited 11-21-2018 07:05
Hello everyone, I hope you're doing well. It's nice to see you @Marrrmaduke, thanks for all your help.
I appreciate some of you have come back and let us know the troubleshooting steps you've tried in hopes to resolve this issue. At this moment, if you haven't done it yet, please update your Versa to the new firmware update.
Please note that this update has only been released to a small group of Fitbit Ionic and Fitbit Versa users. If you have not yet received an update notification and wish to force the update, you can give the watch a FACTORY RESET and then follow steps 1 - 4 below. Please make sure you sync the watch before performing the reset so that all your current data transfer over. Factory resetting your device clears all data from the watch including music, Fitbit Pay information, and apps. Historical Fitbit data will still be available in the Fitbit App.
If you run into trouble updating your Versa, please follow these steps:
I hope this can be helpful, if after updating your Versa, the watch is still not syncing correctly, please let us know.
11-21-2018 16:13
11-21-2018 16:13
11-22-2018 07:22
11-22-2018 07:22
Hello @MTB.Noddy, I hope you're doing well, thanks for taking the time to reply.
I appreciate you have come back and shared your experience with us. Tell me, is the replacement watch having trouble syncing? If so, I would like to gather some information from you so we can check this further. Please reply with as much information as possible:
Thanks for your patience and understanding, we'll be waiting for your next reply.
12-04-2018 15:25
12-04-2018 15:25
Still not syncing!! I am tired of this!!
