03-13-2018
08:58
12:00
AndreaFitbit
03-13-2018
08:58
12:00
AndreaFitbit
I am curious if this device contains the SPO2 sensor that is hopefully going to add to the Fitbit abilities moving forward.
06-27-2019
21:20
19:25
RicardoFitbit
06-27-2019
21:20
19:25
RicardoFitbit
Still not resolved.
Moderator edit: Word choice
Just wanted to reply so I would get updates... I really want the O2 sensor active. Sometimes it seems to work for the sleep cycle, but there's no pattern to it. Is Fitbit testing it at times?
Best Answerhas never been enabled
Best AnswerI need SpO2 monitoring for when I fly my private turbocharged aircraft at altitude. I use a portable pulse oximeter but would like to have the functionality on my Fitbit Versa. I don’t need it for sleep apnea. Any idea when this will be available?
Best AnswerYou can see my post (Parapilot). My daughters bought me mine for my 60th birthday for the same reason as I often launch at 11,000ft and thermal up to 14-15,000. I am beyond pissed off with this company. I ended up buying a cheap rip off https://www.banggood.com/Bakeey-G20-Dynamic-UI-Weather-Target-Setting-HR-Blood-Pressure-Oxygen-Monit... . This does actually work in that it goes down as you go up in altitude but I rely solely on a huge bulky SPO2 clip on which is built into my thermal glove. Unfortunately all of them require you push the button to display a reading which is hard when you are cranking thermals. Personally I would like one inside my helmet like my vertical speed vario that gives different audio tones for different levels. The whole idea of the Fitbit was so I didn't have to carry the clip on finger SPO2. Epic Fail Fitbit to quote my youngest daughter who spent her hard earned cash whilst at college to buy this with her sister.
Sooooooo i suppose fitbit now wants me to buy the versa 2 for the promised SPo2 for just 199 euros ?
shame
Best AnswerWill the original Fitbit Versa indluce sleep features like Sleep Score and smart wake, and use the SP02? The hardware is there and we were promised it would record SP02 as per initial advertising....
If they don't I will never buy a Fitbit product again.
The specs of the Versa2 include the mythical SPO2 sensor. But the features make no mention of it, so it sounds like the vaporware has extended itself to the newest product offering.
@FieryFox99 wrote:Will the original Fitbit Versa indluce sleep features like Sleep Score and smart wake, and use the SP02? The hardware is there and we were promised it would record SP02 as per initial advertising....
Yes, sleep score and smart wake will be coming to the Versa. See footnotes 1 and 6 in the press release for the Versa 2
@pbug56 wrote:The specs of the Versa2 include the mythical SPO2 sensor. But the features make no mention of it, so it sounds like the vaporware has extended itself to the newest product offering.
@pbug56 I think this section of the press release is probably related to the SPO2 sensor:
"Estimated Oxygen Variation Graph : Coming soon, this graph will provide users with an estimate of the variability of oxygen levels in their bloodstream. The data is derived from a combination of the red and infrared sensors on the back of your device. Being aware of short-term variations in the oxygen levels in your bloodstream may indicate variations in your breathing during sleep."
Best AnswerAll analysis charts, of which there are far too many, are based on the data.
If the data is weak it will be like looking through a foggy window. No chart is going to clear that up.
So, obviously, with more detailed heart and O2 data reliably gathered from a finger-based sensor that’s where we’ll go. For some crazy reason, we aren’t there yet.
Of course, that means the watch is superfluous. It can be used but so can the phone. The watch, or phone, can be sitting on the nightstand, if you’re gathering heart and/or SPO2 data at night; which is where it should be.
The finger-sleeve format has other benefits. It may be stable enough for exercise. There are entire fields of data-gathering and analysis waiting to be tapped. But it's possible these watch companies are more interested in marketing on current and nearly un-deliverable promises…They can still make money on unwitting customers today.
But if you’re going to waste your money for those heart and sleep charts, at least wait for the device which can give you the data properly… the finger-based, Bluetooth-enabled sensors. I think I’ve cautioned this for the last time on this thread (the first over 2 years ago).
