02-21-2019 09:02
02-21-2019 09:02
Since the latest Samsung Security System Update both my mother's phone and my phone can no longer sync with the fitbit. I've tried everything that has been recommended on the web. Can anyone help?
02-21-2019 09:50
02-21-2019 09:50
Someone please help as I'm having the same problem
Walt
@Lbierl wrote:Since the latest Samsung Security System Update both my mother's phone and my phone can no longer sync with the fitbit. I've tried everything that has been recommended on the web. Can anyone help?
02-23-2019 14:10
02-23-2019 14:10
Same problem!! SAMSUNG update last night.. now my Fitbit zip won't sync... 😡
02-23-2019 18:41
02-23-2019 18:41
Same here, don't know what to do
02-23-2019 19:49
02-23-2019 19:49
Same problem. I restarted my Zip yesterday and it synced, but now I'm having the same problem again today. I'm not going to restart it every day!!!
02-24-2019 10:11
02-27-2019 14:37 - edited 02-27-2019 14:39
Welcome to the Forums @Lbierl, @Pstodd and @Debbie310. Nice to see you here @waltbros, @BarbaraV58 and @WarAxe.
Thanks for updating your phones and for all the steps that you've tried until now! If you're having syncing issue with your Zip after the update, please confirm that you've tried the following steps on your Android:
Check your phone Permissions and leave location on to keep syncing and getting notifications with your phone, for more info check this suggestions from @ErickFitbit.
If that doesn't work let's check some requirements that your phone and Zip should have in order to successfully communicate:
Requirements:
If the suggested above is not working, it might be that you're having this syncing issues due to the latest Android version, some users have reported some issues with Android 9.0 (Pie) version. If that's the case, we appreciate your patience and look forward to getting you back on track. In the meantime, I'd suggest to sync your tracker with a different device or a PC, so you don't loose your data and you can keep the time on your Fitbit.
Thanks for checking that information, please keep me posted.
02-27-2019 18:10
02-27-2019 18:10
02-27-2019 18:23
02-27-2019 18:23
I'm also having this issue. I've tried everything suggested on this forum, and on forums from 2 years ago! I'm not sure what more to do. It is extremely frustrating!!!! This has to get fixed.
02-27-2019 18:53
02-27-2019 18:53
I am honestly so encouraged to find this thread because I thought it was just me and that something might be wrong with my Fitbit. I've contacted Fitbit support twice and was essentially encouraged to buy a new Fitbit device because we've exhausted all other options. I didn't connect the update to my problems, but that makes total sense! My Fitbit synced perfectly fine until it didn't, apparently after the update.
I have tried everything -- every single thing -- on the troubleshoot page, including checking the list of known bugs, my device is supported (it is, and it has worked fine for 2 months prior to this), reinstalling my Fitbit app, re-setting up my Fitbit Zip through the app, restarting my phone and resetting my device by removing the battery (this last one is the only thing that works). Otherwise, it won't sync at all. I agree with one of the other comments that resetting my battery ever night is not an option!
So, I hope Fitbit is working on this issue...
02-27-2019 19:45
02-27-2019 19:45
02-27-2019 20:26 - edited 02-27-2019 20:27
Yes, I've tried all of these. It will work once after I do the restart, but I refuse to take the battery out every day - that's ludicrous. The groove to open up the back is wearing out. This problem started after the latest Samsung S9+ system update. FitBit needs to figure out what has caused this problem and fix it ASAP.
03-01-2019 07:30
03-01-2019 07:30
Welcome to the Fitbit Forums @Pstodd, @MelaD, @MissyBee37, @Debbie310 and @BarbaraV58. it's nice to see new faces around.
Thank you for following the TS steps that @YojanaFitbit has shared with us. And for letting us know about the steps that have worked for you.
Our team works constantly to correct issues that arise and sometimes it takes time to find the root and resolve the issue.
I really appreciate your feedback and invite you to keep on visiting our community.
03-01-2019 12:21
03-01-2019 12:21
Having the exact same issue as everyone else. Glad to see it's not just me!! Hope the issue gets solved soon!!!
03-08-2019 19:05
03-08-2019 19:05
I'm disappointed with FitBit's response to date. I'm not holding out hope that they're really working on this. I'm guessing they informed Samsung, and have left it in their court... Maybe not. But the lack of communication is very frustrating. Luckily I do have my laptop that I can fire up every few days to record my activity. But I know once I go on vacation, away from my laptop, I'm out of luck... 😞
03-09-2019 07:54
03-09-2019 07:54
Thank you for getting back to us @Stefaniek82 and @BarbaraV58. I apologize for the delayed response and will be glad to assist you with your syncing inquiry.
I appreciate your comments and feedback. Our team is actually working to fix these syncing issues. I know our responses are not what you expect since the issue is still there but I really appreciate your patience.
Keep on visiting the forums.
03-09-2019 13:28
03-09-2019 13:28
I'm also having this issue with my Galaxy Note 8. Is there anything I can do to fix it?
03-10-2019 19:34
03-10-2019 19:34
Andrea - Can you really assist me with my syncing issues? Or is that just a canned response? It's been over three weeks now. If FitBit can't fix the Samsung issue, just tell us. Then I can look at other companies' trackers to see if they will sync properly.
03-11-2019 02:21
03-11-2019 02:21
03-16-2019 09:18
03-16-2019 09:18
Thank you for visiting the forums @Skye1592, @BarbaraV58, @Pstodd. Welcome! I apologize for the delayed response and appreciate your feedback.
Thank you for your comments. Our team is working to fix this situation. You can continue checking help article Why won't my Fitbit device sync?
I appreciate your patience and keep on visiting the forums.
