08-24-2016 21:20
08-24-2016 21:20
I have it set in Settings, Notifications to send me an email when the battery is low. I have not received one of these for a very long time. How do I fix This? Thanks.
Best Answer08-26-2016 07:04
08-26-2016 07:04
Hey there, @zipnotsozippy! Thanks for joining us! In this case I recommend you to uncheck the option on your notifications settings, save the changes, sync your tracker and then check the option again, save and finally sync again.
This should do the trick, if it doesn't you can also try by restarting your tracker and setting it up as a new device by following these instructions:
Let me know how it goes! ![]()
Best Answer08-26-2016 07:56
08-26-2016 07:56
08-30-2016
09:27
08:03
08-30-2016
09:27
08:03
